truffaldino
Junior Member level 3
Hello,
I was trying to design and build a simple solderless breadboard 16MHz transmitter (schametics of final stage is shown on image atached) but incountered a problem with antenna.
I was thinking that antenna is just a piece of wire sticked into the transmitter, but it turned out that designing an antenna is a science.
On my schematics and in LTSPICE simulations I presented antenna as a capacitor+resistance. Then I put inuctance and additional variable capacitor in series to make the antenna resonant.
My antenna is just about 7meters of wire lying on the floor in my room. Tuning capacitor is a cheap 20pf tiny trimmer cap and inductance is 10uH small choke.
According to LTSPICE simulations the energy otput of a resonant antenna is about 0.5watt, but in reality my transmitter range turned out to be a couple of steps from antenna.
I will be grateful if you could explain in simple terms how to tune the antenna using minimal means. As far as I understood I'm using "end feeded dipole antenna" and it has quite high reactance. I thought I could cancel this reactance with the inductance choke, but this simple solutions seems to be wrong.
Thank you in advance
