sehun1119
Junior Member level 1
simulink for sigma delta converters
Hi, all
I am studying for sigma-delta modulation and trying to build a simple second-order sigma-delta modulation in Simulink as a start.
I have gone through a few tutorials and papers, and here is my status.
I put a sine wave as an input and simply add integrators using "unit delay" with feedbacks and 1-bit quantizer as the references that I found show. For the input sine wave, I use a frequency of 2*pi*406.25 and sample time of 1/1024e3.
(I attached a picture of simulink)
My questions are:
1) how do I determine the coefficients in the modulation loop? I guess that is too obious so that I could not find information from any references or I have not searched enough.
2) With any values of coefficients that I chose, I somehow obtained some digital outputs after the sigma delta modulator. Now, I would like to reconstruct the input signal by adding decimators after the modulator output. What rules should I follow?
3) To my understanding by now, the sigma-delta modulator will produce 1-bit digital outputs (2 levels). How is the resolution determined? Is the resolution of this modulation depending on the decimators in demodulation after the modulator? (any relation between decimation factor and resolution?)
Any help or comments would be very appreciated.
Thank you in advance.
Hi, all
My questions are:
