Should I use 500E 5W resistor ?
milan.rajik
Banned
Should the 500E resistor in this circuit be 5W type ? It is a battery charger circuit. 500E is used to trickle charge.
0.3E I have used 5W. 4A will flow to charge a 12V 6Ah battery. Should the 500E also be 5W because it is only used for trickle charging.
hi,
In the worst case where the 500E has say 18V across it, the current thru the 500E is 18V/500 = 36mA, which only 0.65 Watts.
With a 12V battery on the output of the charger there is only 18V -12V = 6V across the 500E, which is 12mA, so thats < 0.1Watt.
I would fit a 0.25W 500E
Eric
no,it shouldn't be 5W....for example if your input is 18V and battery is charging at 13V,then 18-13/500= 10mA current will flow through it.So,its power should be >0.05W..
But I think Battery charging is done at 14V 4 Amps.
i fear,you will damage your battery if you charge it at 4A... 4A is much greater for 6Ah battery....
anyway,0.3E resistor should be greater than 5W ( about 8W or 10W )...
0.2W 10W is not available. What next value of resistance can I use which is 10W type. Should I use 2 X 0.1E 10W in series ?
yes,you can use it,,now equivalent will be 0.2E,So,now power rating for each resistor should be greater than 1.6W...you can also use 2 x 0.1E of each 5W rating
So, Can I use a 18V 2 Amp or 3 Amp transformer with a bridge circuit for charging power supply ?
which battery you are using? lead acid?
see this...**broken link removed**
you can use the first circut...it has current limit,which will not damage you transformer or lm317or battery....
In the first circuit at this page what is the wattage of resistor named see text. I have set charging current to 600 mA. so 0.6/0.6 = 1E resistance. What should be wattage 1/4W, 1/2W, 1W, 5W ?
