Sink0
Full Member level 6
- Joined
- Nov 25, 2009
- Messages
- 390
- Helped
- 37
- Reputation
- 74
- Reaction score
- 30
- Trophy points
- 1,308
- Location
- Sao Paulo, Brazil
- Activity points
- 4,186
Hi i have several questions about a cheap level translation for I2C. I was looking at this **broken link removed** and how they did the level translation to a 5V uC talk to the accelerometer. My first question is... is the I2C clock open drain? Will that translation with the Schottky diode work for the clock line? Can i use any Schottky diode (with something like 30V reverse voltage)? They do not make any kind of conversion for interrupt lines. Is 3.3V enough to set a TTL high level? Can i use a common emitter transistor with the colector connected to the uC Pin and a pull-up pin to 5V for 3.3->5V conversion for interrupt pins?
Thank you!!
Thank you!!
