Sequential Circuit
Basit Mehmood
Newbie
What happened if we use blocking assignment in sequential circuit like flip-flop?
I mean is following code correct or not?
Code Verilog - [expand]
8
9
10
module dff (q, qn, d, clk);
   input d, clk;
   output q, qn;
   reg q, qn;
   always @(posedge clk)
      begin
         q = d;
         qn = ~d;
      end
endmodule
conceptually, it is wrong.
depending on the synthesis tool, it might synthesize correctly.
    andre_luis
1. What do you want to achieve? Just playing around?
There's a reason, why design rules say use non-blocking in clocked always block and blocking in combinational. For a comprehensive explanation, read this classical paper http://www.sunburst-design.com/papers/CummingsSNUG2000SJ_NBA_rev1_2.pdf
2. In this special case, non-blocking assignments make no difference. That's because the assigned variable q and qn aren't appearing on RHS of other expressions below the assignment.
3. Sometimes you want intermediate combinational results assigned to a variable inside a clocked always block. In this case, blocking assignments may be used intentionally.
