Sending ADC data to PC via USB for pic18f4550
prongs1911
Newbie level 6
I am trying to send data from the inbuilt ADC of pic18f4550 to PC using USB. I successfully wrote a code for ADC to send data over serial port for testing.I have also modified the USB CDC-BASIC DEMO from microchip framework to echo back the data sent from PCand I was able to send and recieve data using realterm. But I have not been able to combine both. What I tried was, I wrote the ADC part of the code in void user(void) after if((USBDeviceState < CONFIGURED_STATE)||(USBSuspendControl==1)) return;,but i was not getting any output on Realterm.
Is this the correct approach or do I need to do something else?
Please help. I have to submit this project in another 5 days.
ADC code:
#include <p18f4550.h>
#include <delays.h>
#include <adc.h>
#include <usart.h>
#include <stdlib.h>
  #pragma config FOSC = HSPLL_HS  // 20 MHz crystal.
        #pragma config PLLDIV = 5               // Divide by 5 to provide the 96 MHz PLL with 4 MHz input.
        #pragma config CPUDIV = OSC1_PLL2 // Divide 96 MHz PLL output by 2 to get 48 MHz system clock.
        #pragma config USBDIV = 2               // "USB clock source comes from the 96 MHz PLL divided by 2."
        #pragma config FCMEN = OFF // "Fail-Safe Clock Monitor disabled."
        #pragma config IESO = OFF  // "Oscillator Switchover mode disabled."
        #pragma config PWRT = OFF  // "PWRT disabled."
        #pragma config WDT = OFF   // "HW Disabled - SW Controlled."
        #pragma config MCLRE = ON  // "MCLR pin enabled; RE3 input pin disabled."
        #pragma config BOR = ON // Brown Out Reset enabled in hardware. In case of supply voltage drop, BOR resets the device to prevent erratic CPU behavior.
        #pragma config BORV = 3 // BOR occurs at 2V (1.2V below the minimum required voltage for the HSPLL oscillator mode).
        #pragma config VREGEN   = ON       //USB Voltage Regulator
        #pragma config LVP = OFF   // Disable low voltage ICSP
        #pragma config ICPRT = OFF // Disable dedicated programming port (44-pin devices)
        #pragma config CP0 = OFF   // Disable code protection
#define LEDPin LATDbits.LATD2 //Define LEDPin as PORT D Pin 1
#define LEDTris TRISDbits.TRISD2 //Define LEDTris as TRISD Pin 1
void main()
	int delay;
	unsigned char result=0;
	unsigned char lsByte=0;
	unsigned char msByte=0;
	unsigned int ADCstate = 0;
	LEDTris = 0;//Set LED Pin data direction to OUTPUT
	LEDPin = 1;//Set LED Pin
	ADCON1 = 0b00001110;//VSS,VDD ref. AN0 analog only
	ADCON0 = 0x00;//clear ADCON0 to select channel 0 (AN0)
	ADCON2 = 0b00001110;//ADCON2 setup: Left justified, Tacq=2Tad, Tad=64*Tosc (or Fosc/64)
	ADCON0bits.ADON = 0x01;//Enable A/D module
	OpenUSART(USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE &
	USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_LOW, 255);
	while(1)
	switch(ADCstate)
				case 0:	SetChanADC(ADC_CH0);
						ADCstate++;
				break;
				case 1:	ConvertADC();
						ADCstate++;
				break;
				case 2: if(BusyADC())
						{	break;
						else
						{	ADCstate++;
							break;
				case 3: lsByte = ADRESL;
						msByte = ADRESH;
						ADCstate++;
				break;
				case 4:
							putcUSART(msByte);
						ADCstate=0;
				break;
				default: ADCstate=0;
				break;
USB-CDC echo code:
#include "p18f4550.h"
#include "./USB/usb.h"
#include "./USB/usb_function_cdc.h"
#include "main.h"
void user(void)
        BYTE numBytesRead;
        //Blink the LEDs according to the USB device status
        BlinkUSBStatus();
        // User Application USB tasks
        if(USBUSARTIsTxTrfReady())
                numBytesRead = getsUSBUSART(USB_Out_Buffer,64);
                if(numBytesRead != 0)
                        BYTE i;
                        for(i=0;i<numBytesRead;i++)
                                switch(USB_Out_Buffer[i])
                                        case 0x0A:
                                        case 0x0D:
                                                USB_In_Buffer[i] = USB_Out_Buffer[i];
                                                break;
                                        default:
                                                USB_In_Buffer[i] = USB_Out_Buffer[i];// + 1;
                                                break;
                        putUSBUSART(USB_In_Buffer,numBytesRead);
        CDCTxService();
Can no one help me? I am totally stuck. I would really appreciate some suggestions.
Re: Sending ADC data to PC via USB for pic18f4550 (replace your user.c with this one)
* Microchip USB C18 Firmware Version 1.2
* FileName: user.c
* Dependencies: See INCLUDES section below
* Processor: PIC18
* Compiler: C18 3.11+
* Company: Microchip Technology, Inc.
* Software License Agreement
* The software supplied herewith by Microchip Technology Incorporated
* (the “Company”) for its PICmicro® Microcontroller is intended and
* supplied to you, the Company’s customer, for use solely and
* exclusively on Microchip PICmicro Microcontroller products. The
* software is owned by the Company and/or its supplier, and is
* protected under applicable copyright laws. All rights are reserved.
* Any use in violation of the foregoing restrictions may subject the
* user to criminal sanctions under applicable laws, as well as to
* civil liability for the breach of the terms and conditions of this
* license.
* THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
* TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
* Author Date Comment
* Rawin Rojvanit 11/19/04 Original.
* Rawin Rojvanit 05/14/07 A few updates.
* CDC RS-232 Emulation Tutorial Instructions:
* Refer to Application Note AN956 for explanation of the CDC class.
* First take a look at Exercise_Example() and study how functions are called.
* There are five exercises, each one has a solution in the CDC\user\solutions.
* Scroll down and look for Exercise_01,_02,_03,_04, and _05.
* Instructions on what to do is inside each function. The exercises make use
* of LEDs, general purpose pushbuttons, and the temperature sensor found on
* the PICDEM FS USB Demo Board. Excercises 1 and 4 can be used directly
* on the PIC18F87J50 FS USB Plug-In Module board, but the other exercises use
* hardware items not phsyically present (such as temperature sensor) on the
* board.
/** I N C L U D E S **********************************************************/
#include <p18cxxx.h>
#include "system\typedefs.h"
#include "system\usb\usb.h"
#include "io_cfg.h" // I/O pin mapping
#include "user\user.h"
#include "user\temperature.h"
#define sw PORTEbits.RE2
/** V A R I A B L E S ********************************************************/
#pragma udata
byte old_sw2,old_sw3;
char input_buffer[64];
char output_buffer[64];
char adc0data[9];
char adc1data[11];
unsigned int data0=1234, data1;
unsigned int d1,d2,d3,d4,x,y;
rom char welcome[]={"Full-Speed USB - CDC RS-232 Emulation Demo\r\n\r\n"};
rom char ansi_clrscr[]={"\x1b[2J"}; // ANSI Clear Screen Command
/** P R I V A T E P R O T O T Y P E S ***************************************/
void InitializeUSART(void);
void BlinkUSBStatus(void);
BOOL Switch2IsPressed(void);
BOOL Switch3IsPressed(void);
void adc(unsigned char ch);
void Exercise_Example(void);
void adcusb();
void display0();
void display1();
//void dec2ascii(unsigned int dec,unsigned char c);
void dec2ascii(unsigned int dec);
void delay_s(unsigned char d);
void delay_ms(unsigned char d);
void Exercise_01(void);
void Exercise_02(void);
void Exercise_03(void);
void Exercise_04(void);
void Exercise_05(void);
/** D E C L A R A T I O N S **************************************************/
#pragma code
void UserInit(void)
mInitAllLEDs();
mInitAllSwitches();
old_sw2 = sw2;
#if defined(PIC18F4550_PICDEM_FS_USB)
old_sw3 = sw3;
InitTempSensor();
#endif
InitializeUSART();
}//end UserInit
TRISCbits.TRISC7=1; // RX
TRISCbits.TRISC6=0; // TX
SPBRG = 0x71;
#if defined(__18F87J50)||defined(__18F86J55)|| \
defined(__18F86J50)||defined(__18F85J50)|| \
defined(__18F67J50)||defined(__18F66J55)|| \
defined(__18F66J50)||defined(__18F65J50)
SPBRGH1 = 0x02; // 0x0271 for 48MHz -> 19200 baud
#else
SPBRGH = 0x02; // 0x0271 for 48MHz -> 19200 baud
#endif
TXSTA = 0x24; // TX enable BRGH=1
RCSTA = 0x90; // continuous RX
BAUDCON = 0x08; // BRG16 = 1
}//end InitializeUSART
void putsUSART(char *data)
do
{ // Transmit a byte
while(!TXSTAbits.TRMT);
TXREG = *data; // Write the data byte to the USART, 8-bit mode only
} while( *data++ );
* Function: void ProcessIO(void)
* PreCondition: None
* Input: None
* Output: None
* Side Effects: None
* Overview: This function is a place holder for other user routines.
* It is a mixture of both USB and non-USB tasks.
* Note: None
BlinkUSBStatus();
if((usb_device_state < CONFIGURED_STATE)||(UCONbits.SUSPND==1)) return;
//Exercise_Example();
//convert(1234);
//dec2ascii(1234);
//while(1)
adcusb();
//Exercise_01();
//Exercise_02();
//Exercise_03();
//Exercise_04();
//Exercise_05();
}//end ProcessIO
/*********************************************my ADC example************************************************/
void adcusb(void)
TRISEbits.TRISE2=1;
if(sw==0)
// ADCON1=0x0e; //Configure analog pins, voltage reference and digital I/O
adc(0);
display0();
//adc(1);
//display1();
void display0()
if(mUSBUSARTIsTxTrfReady())
mUSBUSARTTxRam((byte*)adc0data,9);
void display1()
mUSBUSARTTxRam((byte*)adc1data,11);
unsigned float x,y,z,r,a,c;
if(ch==0)
ADCON0bits.CHS0=0; //Analog Channel_0 Select bits
ADCON0bits.CHS1=0;
ADCON0bits.CHS2=0;
ADCON0bits.CHS3=0;
if(ch==1)
ADCON0bits.CHS0=1; //Analog Channel_1 Select bits
ADCON0bits.CHS1=0;
ADCON0bits.CHS2=0;
ADCON0bits.CHS3=0;
ADCON2bits.ACQT0=1; //A/D Acquisition Time Select bits
ADCON2bits.ACQT1=1;
ADCON2bits.ACQT2=1;
ADCON2bits.ADCS0=1; //A/D Conversion Clock Select bits
ADCON2bits.ADCS1=0;
ADCON2bits.ADCS2=1;
ADCON2bits.ADFM=1; //Data right adjusted
ADCON0bits.ADON=1; //A/D converter module is enabled
ADCON0bits.GO=1;//A/D Conversion Status bit
while(ADCON0bits.GO==1);//Waiting for A/D conversion to complete
delay_ms(2);
y=ADRESL;
x=ADRESH;
z=256*x+y;
a=z*10;
c=a*4.8828125;
r=c/50;
//if(ch==0)
dec2ascii(z);
if(ch==1)
dec2ascii(z,1);
d1=dec/1000;
x=dec%1000;
d2=x/100;
y=x%100;
d3=y/10;
d4=y%10;
d1=d1|0x30;
d2=d2|0x30;
d3=d3|0x30;
d4=d4|0x30;
//if(c==0)
adc0data[0]=d1|0x30;
adc0data[1]=d2|0x30;
adc0data[2]=d3|0x30;
adc0data[3]=('.');
adc0data[4]=d4|0x30;
adc0data[5]=('°');
adc0data[6]=('C');
adc0data[7]=('\r');
//adc0data[8]=('\n');
//adc0data[7]=(' ');
adc0data[8]=0x00;
if(c==1)
adc1data[0]=d1|0x30;
adc1data[1]=d2|0x30;
adc1data[2]=d3|0x30;
adc1data[3]=('.');
adc1data[4]=d4|0x30;
adc1data[5]=('%');
adc1data[6]=('r');
adc1data[7]=('H');
adc1data[8]=('\r');
adc1data[9]=('\n');
adc1data[10]=0x00;
unsigned char j,k;
int i;
for(j=0;j<d;j++)
for(k=0;k<1;k++)
for(i=0;i<235;i++);
int i,j,k;
for(j=0;j<d;j++)
for(k=0;k<505;k++)
for(i=0;i<549;i++);
static byte start_up_state = 0;
if(start_up_state == 0)
if(Switch2IsPressed())
start_up_state++;
else if(start_up_state == 1)
putrsUSBUSART(ansi_clrscr);
start_up_state++;
else if(start_up_state == 2)
putrsUSBUSART("\rMicrochip Technology Inc., 2007\r\n");
start_up_state++;
else if(start_up_state == 3)
putrsUSBUSART(welcome);
start_up_state++;
}//end Exercise_Example
//void Exercise_01(void)
/* Insert code here - 3 lines */
//if(Switch2IsPressed())
putrsUSBUSART("usb data\r\n");
* Write code in this function that sends a literal null-terminated
* string of text ("Hello World!\r\n") to the PC when switch 2 is
* pressed.
* Useful functions:
* Switch2IsPressed() returns '1' when switch 2 is pressed.
* putrsUSBUSART(...);
* See examples in Exercise_Example();
* Remember, you must check if cdc_trf_state is ready for another
* transfer or not. When it is ready, the value will equal CDC_TX_READY,
* or use macro: mUSBUSARTIsTxTrfReady()
/* End */
}//end Exercise_01
rom char ex02_string[]={"Type in a string here.\r\n"};
* Write code in this function that sends a null-terminated string
* of text stored in program memory pointed to by "ex02_string" to
* the PC when switch 3 is pressed.
* ex02_string is declared right above this function.
* Useful functions:
* Switch3IsPressed() returns '1' when switch 3 is pressed.
/* Insert code here - 3 lines*/
/* End */
}//end Exercise_02
* Write code in this function that reads data from USB and
* toggles LED D4 when the data read equals ASCII character '1' (0x31)
* Useful functions:
* byte getsUSBUSART(char *buffer, byte len) See cdc.c for details
* mLED_4_Toggle();
* Use input_buffer[] to store data read from USB.
/* End */
}//end Exercise_03
* Before starting Exercise_04(), comment out the call to Exercise_01()
* in ProcessIO(); This function will need to check Switch2IsPressed().
* Write code in this function that sends the following 4 bytes of
* data: 0x30,0x31,0x32,0x33 when switch 2 is pressed.
* Note that these data is not null-terminated and is located in
* the data memory.
* Useful functions:
* mUSBUSARTTxRam(byte *pData, byte len) See cdc.h for details.
* Use output_buffer[] to store the four bytes data.
/* Insert code here - 7 lines */
/* End */
}//end Exercise_04
* The PICDEM Full-Speed USB Demo Board is equipped with a
* temperature sensor. See temperature.c & .h for details.
* All necessary functions to collect temperature data have
* been called. This function updates the data a few times
* every second. The program currently sends out the
* temperature data to the PC via UART.
* You can check this by hooking up a serial cable and
* set your serial port to 19200 baud, 8 bit data, 1 Stop,
* no parity.
* The program assumes CPU Frequency = 48 MHz to generate
* the correct SPBRG value for 19200 baud transmission.
* Modify the code to send the ASCII string stored in
* tempString to the PC via USB instead of UART.
* The temperature data is stored in tempString array in
* ASCII format and is null-terminated.
* Useful function:
* putsUSBUSART(...);
* Note: It is 'puts' and not 'putrs' to be used here.
static word ex05_count;
if(ex05_count == 0)
AcquireTemperature(); // Read temperature from sensor
#endif
UpdateCelsiusASCII(); // Convert to ASCII, stored in
// "tempString", See temperature.c
/* Modify the code below - 3 lines */
putsUSART(tempString);
ex05_count = 10000;
/* End */
else
ex05_count--;
}//end Exercise_05
* Function: void BlinkUSBStatus(void)
* Input: None
* Output: None
* Overview: BlinkUSBStatus turns on and off LEDs corresponding to
* the USB device state.
* Note: mLED macros can be found in io_cfg.h
* usb_device_state is declared in usbmmap.c and is modified
* in usbdrv.c, usbctrltrf.c, and usb9.c
static word led_count=0;
if(led_count == 0)led_count = 10000U;
led_count--;
#define mLED_Both_Off() {mLED_1_Off();mLED_2_Off();}
#define mLED_Both_On() {mLED_1_On();mLED_2_On();}
#define mLED_Only_1_On() {mLED_1_On();mLED_2_Off();}
#define mLED_Only_2_On() {mLED_1_Off();mLED_2_On();}
if(UCONbits.SUSPND == 1)
if(led_count==0)
mLED_1_Toggle();
mLED_2 = mLED_1; // Both blink at the same time
}//end if
else
if(usb_device_state == DETACHED_STATE)
mLED_Both_Off();
else if(usb_device_state == ATTACHED_STATE)
mLED_Both_On();
else if(usb_device_state == POWERED_STATE)
mLED_Only_1_On();
else if(usb_device_state == DEFAULT_STATE)
mLED_Only_2_On();
else if(usb_device_state == ADDRESS_STATE)
if(led_count == 0)
mLED_1_Toggle();
mLED_2_Off();
}//end if
else if(usb_device_state == CONFIGURED_STATE)
if(led_count==0)
mLED_1_Toggle();
mLED_2 = !mLED_1; // Alternate blink
}//end if
}//end if(...)
}//end if(UCONbits.SUSPND...)
}//end BlinkUSBStatus
if(sw2 != old_sw2)
old_sw2 = sw2; // Save new value
if(sw2 == 0) // If pressed
return TRUE; // Was pressed
}//end if
return FALSE; // Was not pressed
}//end Switch2IsPressed
if(sw3 != old_sw3)
old_sw3 = sw3; // Save new value
if(sw3 == 0) // If pressed
}//end if
}//end Switch3IsPressed
#endif
/** EOF user.c ***************************************************************/
