Scrolling messages to left pic16F887 mikroC pro
is the code for scrolling from right to left or from left to right? can the max232 work with this code? thx
Sorry. It is scrolling messages to from right to left.
Yes u can do max232.
Right now, I am moving into ARM7 NETDUINO GO by using Net Micro Framework
?@supra_56
sir, i have this project interfacing this LED scrolling display to a ps/2 keyboard.. can you please help me?
Re: Scrolling messages to left pic16F887 8x32 dot matrix mikroC pro
Can u tell me the actual connection of a dot matrix display when implementing on breadboard. Cz I found differences with the datasheet in practical connection.
https://www.edaboard.com/threads/152066/
Scroll down and look for ilker_32.
I used bi-color 8x8 dotmarix common cathode. If u look @ ilker_32's schematic. The bottom is columns and the top is rows
On top of rows, the 595 pins Q7 connect to rows first pins and Q6 connect to second pin of row and so on. Look at datasheet for row pin. All datasheet are same but differences with pins numbers..
Kindly, send me ur datasheet.
Let me know.
Hi Supra. Just eager to know if this cct by Mr-aeddy can work with your 32x8 mikrobasic codes. Thanks
I've worked on 8x40 dot matrix display using PIC16F877A,74HC595.
I'm using proteus and mikro C for simulating and coding .
check my attachments.
  • Scrol msg.txt
Hi jigarpatelp
I'm using 32x8 cct previusly on MikroBasic and 74HC154 by Supra, I need to replace this Demux with 74hc595. Please share any Idea.
Thanks
Hi Supra_56
I've added an additional code for 595 on your MikroB code, please let me know if ok
Code Basic4GL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
' * Description: Scrolled to left
' *modified by: supra
' * Test configuration:
' MCU: PIC16F628A
' Misc: 74hc595; 8*32 dot matrix
' Oscillator: 20.0000 MHz
' config: PWRITE_ON, WDT_OFF, LVP_OFF, HS
' Ext. Modules: -
' SW: mikroBasic V7.0.0.2
program text 'With 74HC595: RA0 = Data, RA1 = Clock, RA2 = Latch
const text as integer[262] =(
$7F, $09, $09, $09, $06, $00, ' P
$41, $7F, $41, $00, ' I
$3E, $41, $41, $41, $22, $00,' C
$42, $7F, $40, $00, ' 1
$3C, $4A, $49, $49, $30, $00,' 6
$7F, $09, $09, $01, $01, $00,' F
$42, $61, $51, $49, $46, $00,' 2
$36, $49, $49, $49, $36, $00,' 8
$7E, $11, $11, $11, $7E, $00,' A
$00, $00, $00, $00, $00, $00,' space
$7F, $20, $18, $20, $7F, $00,' W
$44, $7D, $40, $00, ' i
$04, $3F, $44, $40, $20, $00, 't
$7F, $08, $04, $04, $78, $00, 'h
$01, $71, $09, $05, $03, $00,' 7
$18, $14, $12, $7F, $10, $00,' 4
$7F, $08, $08, $08, $7F, $00,' H
$00, $42, $7F, $40, $00, ' 1
$27, $45, $45, $45, $39, $00,' 5
$63, $14, $08, $14, $63, $00,' X
$21, $41, $45, $4B, $31, $00,' 3
$7F, $02, $04, $02, $7F, $00,' M
$20, $54, $54, $54, $78, $00, 'a
$7C, $08, $04, $04, $08, $00, 'r
$44, $7D, $40, $00, 'i
$44, $28, $10, $28, $44, $00, 'x
$7F, $10, $28, $44, $00, 'k
$38, $44, $44, $44, $38, $00, 'o
$7F, $49, $49, $49, $36, $00,' B
$48, $54, $54, $54, $24, $00, 's
$38, $44, $44, $44, $44, $00) 'c
dim i, x as byte
dim temp_array as byte[32]
dim shift, a, value, column as integer
'dim number as word
'dim txt as string[5]
dim number as byte
dim y as byte
    sub procedure Clock
        PORTA.1 = 1 'portA.1 is high
        nop  'no operation
        PORTA.1 = 0 'portA.1 is low
    end sub
    sub procedure Latch
        PORTA.2 = 1 'portA.2 is high
        nop   'no operation
        PORTA.2 = 0 'portA.2 is low
    end sub
    sub procedure Output(dim value as byte)
        dim x as byte
        PORTA.2 = 0 ' make Latch bit2 of portA low
        for x = 0 to 7   ' loops for a count of eight
            PORTA.0 = value.x
            Clock
        next x
        PORTA.2 = 1 ' make Latch bit high to latch new data to the outputs
                    ' of the HC595.
         Latch
    end sub
main:
'Set int Port operations
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
' Calculate the number of columns in the text
column = 262
'Temporary array reset
    for i = 0 to 31
    temp_array[i] = 0 'Array elements start out 0
    next i
while true
'Shift operations
    for shift = -32 to column 'prolong spaces to repeat again
'16 columns of text divided into pieces
   for i = 0 to 31
   value = i + shift
   if(value > 0) then
   temp_array[i] = 0 ' text input
end if
if(value >= 0) and (value <= column - 1) then
temp_array[i] = text[value]
end if
if(value > column) then
temp_array[i] = 0
end if
next i
'Scanning process
for a = 0 to 25 'control scrolling speeds...highuer number is slowest and lowest number is fastest
for x = 0 to 31 'Temporary array view
ClearBit(PORTA, i) 'Clear the Ghost locations ready for starting
portb.i = 0
portb = temp_array[x] 'send data to PortB
porta = x 'select the corresponding column
Next x
next a
next shift
wend
goto start
end.
