How to use 16f877A instead of 18F452 in LedMatrix
smsm3650
Member level 2
this is the oreginal project with 18f452
after modefing it to use 16f877A it became
but this error Appear's
Another Question .. what does the Extention PBP mean ,, what is this Language or what is it's Compiler ..
What can We Do ???
  • ledmmatrix_mowing_2059.rar
instade
have you altered 16f877a in same design you used for 18f452.. some times exception occurs when we do so.. Create new design for this circuit .. this sometimes works....
    V
18f452 vs 16f877
this is A Very Simple program .. Any Microcontroll Can run it .. i'm sure that 877 Can be used instade of it
    V
led matrix 16f877a ccs
i think the cause is the different in ram size and it is big for pic18f452 than pic16f877A
the code using 2d array which is need more ram capacity
you must rewrite the code to proportion your pic
thanks
18f452
If You have another Idea to this project >> Tell Us about it
18f452 fuses mikroc
are u using same hex file for 16F877A?
if it is . t will not work
compile another hex file
16f877a scrolling message display circuits
"sutun_reg" ---> 320byte... You aren't use 16F877(A). But you can change source codes.
i can send to you different a project?
are you want?
Added after 23 minutes:
#include <16F877.H>
#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_A4, rcv=PIN_A5,RESTART_WDT, ERRORS)
#define PIN_ST_CP      PIN_C2  // RCLK ----> Pin 12 ST_CP
#define PIN_SH_CP      PIN_C3  // SRCLK ---> Pin 11 SH_CP
#define PIN_SER_IN     PIN_C5  // SER -----> Pin 14
//#define PIN_MRS       PIN_C1  // PIN 10
//#define PIN_OE        PIN_C3  // PIN 13
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
long s1_char_size=41;
char s1[79];
long i;
//***********************sutunlara bağlı hc595**********************************
#define clock      PIN_B0  // RCLK ----> Pin 12 ST_CP
#define latch      PIN_B2  // SRCLK ---> Pin 11 SH_CP
#define data       PIN_B1  // SER -----> Pin 14
void HC595_OUT_satir(unsigned char send_data)
   unsigned char bit_mask;
   for (bit_mask=1; bit_mask ;bit_mask <<=1)
      // On an AVR you can set the bit directly and i'd use
      // "data = (send_data & bit_mask);"
      //Else use this if/else ....
      if((send_data & bit_mask))
        output_high(data);
      else
        output_low(data);
      output_high(clock);
      delay_us(1);
      output_low(clock);
   output_high(latch);
   delay_us(1);
   output_low(latch);
void get_line1(void)
  for(i=0; i<s1_char_size; i++)
    if(kbhit())
      s1[i]=getc();
      delay_cycles(2);
      printf("%C",s1[i]);
      delay_us(1);
    else
      i -= 1;
const char   msg_default[] = "Sofie & ilker";
const char   ascii1[32][5] = {
   {0b00000000, //   0
    0b00000000,
    0b00000000,
    0b00000000,
    0b00000000}
   {0b00000000, //   1
    0b00000000,
    0b01011111,
    0b00000000,
    0b00000000}
   {0b00000000, //   2
    0b00000111,
    0b00000000,
    0b00000111,
    0b00000000}
   {0b00010100, //   3 ("#" iºareti)
    0b01111111,
    0b00010100,
    0b01111111,
    0b00010100}
   {0b00100100, //   4 ("$" iºareti)
    0b00101010,
    0b01111111,
    0b00101010,
    0b00010010}
   {0b00100111, //   5 ("%" iºareti)
    0b00010101,
    0b01101011,
    0b01010100,
    0b01110010}
   {0b00110110, //   6
    0b01001001,
    0b01010110,
    0b00100000,
    0b01010000}
   {0b00000000, //   7
    0b00001011,
    0b00000111,
    0b00000000,
    0b00000000}
   {0b00000000, //   8 ( ")" iºareti)
    0b00011100,
    0b00100010,
    0b01000001,
    0b00000000}
   {0b00000000, //   9 ( "(" iºareti)
    0b01000001,
    0b00100010,
    0b00011100,
    0b00000000}
   {0b00101010, //   10
    0b00011100,
    0b01111111,
    0b00011100,
    0b00101010}
   {0b00001000, //   11 ( "+" iºareti)
    0b00001000,
    0b00111110,
    0b00001000,
    0b00001000}
   {0b00000000, //   12 ( "'" iºareti)
    0b01011000,
    0b00111000,
    0b00000000,
    0b00000000}
   {0b00001000, //   13 ("-" iºareti)
    0b00001000,
    0b00001000,
    0b00001000,
    0b00001000}
   {0b00000000, //   14
    0b01100000,
    0b01100000,
    0b00000000,
    0b00000000}
   {0b00100000, //   15 ("/" iºareti)
    0b00010000,
    0b00001000,
    0b00000100,
    0b00000010}
   {0b00111110, //   16 ( 0 rakamı )
    0b01010001,
    0b01001001,
    0b01000101,
    0b00111110}
   {0b00000000, //   17 ( 1 rakamı)
    0b01000010,
    0b01111111,
    0b01000000,
    0b00000000}
   {0b01110010, //   18 ( 2 rakamı)
    0b01001001,
    0b01001001,
    0b01001001,
    0b01000110}
   {0b00100010, //   19 ( 3 rakamı)
    0b01000001,
    0b01001001,
    0b01001001,
    0b00110110}
   {0b00011000, //   20 ( 4 rakamı)
    0b00010100,
    0b00010010,
    0b01111111,
    0b00010000}
   {0b00100111, //   21 ( 5 rakamı)
    0b01000101,
    0b01000101,
    0b01000101,
    0b00111001}
   {0b00111100, //   22 ( 6 rakamı)
    0b01001010,
    0b01001001,
    0b01001001,
    0b00110000}
   {1, 113, 9, 5, 3}           //   23
   {54, 73, 73, 73, 54}        //   24
   {6, 73, 73, 41, 30}         //   25
   {0, 54,54,0,0}         // {0, 54, 54,0,0,0}
   //   26
   {0, 91, 59, 0,0}         // {0, 91, 59,0,0,0}     // 27
   {8, 20, 34, 65,0}           //   28
   {20, 20, 20, 20, 20}        //   29
   {65, 34, 20, 8,0}           //   30
   {2, 1, 81, 9, 6}            //   31
const char   ascii2[32][5] = {
{50, 73, 121, 65, 62}          //      0
{124, 18, 17, 18, 124}         //      1   A
{65, 127, 73, 73, 54}          //      2   B
{62, 65, 65, 65, 34}           //      3   C
{65, 127, 65, 65, 62}          //      4   D
{127, 73, 73, 65, 65 }         //      5   E
{127, 9, 9, 1, 1}              //      6
{62, 65, 73, 73, 58}           //      7
{127, 8, 8, 8, 127}            //      8
{0, 65, 127, 65, 0}       // {0, 65, 127, 65,0,0}
        //      9
{32, 64, 65, 63, 1}            //      10
{127, 8, 20, 34, 65}           //      11
{127, 64, 64, 64, 64}          //      12
{127, 2, 12, 2, 127}           //      13
{127, 2,  4, 8, 127}           //      14
{62, 65, 65, 65, 62}           //      15
{127, 9, 9, 9, 6}              //      16
{62, 65, 81, 33, 94}           //      17
{127, 9, 25, 41, 70}           //      18
{38, 73, 73, 73, 50}           //      19
{1,1,127, 1, 1}                //      20
{63, 64, 64, 64, 63}           //      21
{7, 24, 96, 24, 7}             //      22
{127, 32, 24, 32, 127}         //      23
{99, 20, 8, 20, 99}            //      24
{3, 4, 120, 4, 3}              //      25
{97, 81, 73, 69, 67}           //      26
{0, 127, 65, 65,0}          // {0, 127, 65, 65,0,0}
          //      27
{2, 4, 8, 16, 32}              //      28
{0, 65, 65, 127,0}          // {0, 65, 65, 127,0,0}
          //      29
{4, 2, 1, 2, 4}                //      30
{64, 64, 64, 64, 64}           //      31
const char   ascii3[32][5] = {    // 0 -- 30 == 31 elements
   {0, 0, 7, 11,0}        // {0, 7, 11,0,0,0}
  //   0
   {32, 84, 84, 84, 56}     //   1
   {127, 40, 68, 68, 56}    //   2
   {56, 68, 68, 68,0}     //   3
   {56, 68, 68, 40, 127}     //   4
   {56, 84, 84, 84, 24}     //   5
   {8, 126, 9, 9, 2}     //   6
   {8, 84, 84, 84, 60}     //   7
   {127, 8, 4, 4, 120}     //   8
   {0, 68, 125, 64,0}      // {0, 68, 125, 64,0,0}
//   9
   {32, 64, 68, 61,0}     //   10
   {127, 16, 40, 68,0}     //   11
   {0, 65, 127, 64, 0}      // {0, 65, 127, 64,0,0}
//   12
   {124, 4, 120, 4, 120}     //   13
   {124, 8, 4, 4, 120}     //   14
   {56, 68, 68, 68, 56}     //   15
   {124, 20, 20, 20, 8}     //   16
   {8, 20, 20, 20, 124}     //   17
   {124, 8, 4, 4, 8}     //   18
   {72, 84, 84, 84, 36}     //   19
   {4, 63, 68, 68,0}     //   20
   {60, 64, 64, 32, 124}     //   21
   {28, 32, 64, 32, 28}     //   22
   {60, 64, 48, 64, 60}     //   23
   {68, 40, 16, 40, 68}     //   24
   {12,80, 80, 80, 60}     //   25
   {68, 100, 84, 76, 68}     //   26
   {0, 8, 54, 65,0}           // {0, 8, 54, 65,0,0}
//   27
   {0,0,119,0,0}             // {0, 119,0,0,0,0}     // 28
   {0, 65, 54, 8,0}           // {0, 65, 54, 8,0,0}
//   29
   {2,1,2,4,2}     //   30
   {0b01111101, // ö harfi
    0b10000010,
    0b10000010,
    0b10000010,
    0b01111101,
void main(void)
  int char_index;
  int col_index;
  int x = 0;
  long MSD, LSD;
  int delaycount;
  int16 startposition;
  set_tris_b(0);
  set_tris_c(0x40);
  set_tris_d(0);
  HC595_OUT_satir(0);
  output_c(0);
  startposition = 0;
  for(i=0; i<79; i++)
    s1[i] = 46;
  for(i=0; i<sizeof(msg_default); i++)
    s1[i] = msg_default[i];
  delay_ms(100);
  do
    if(!input(PIN_E1)) //BUTONA BASILDI MI?
      do
        delay_cycles(2);
        printf("\f\r\n");
        printf("\f\r\n Kac karakter.(0--99):");
        MSD=getc();
        delay_cycles(2);
        printf("%C",MSD);
        delay_us(1);
      }while(!isamoung(MSD,"0123456789"));
      do
        LSD=getc();
        delay_cycles(2);
        printf("%C",LSD);
        delay_us(1);
      }while(!isamoung(LSD,"0123456789"));
      s1_char_size = 10*(MSD-48) + (LSD-48);
      delay_cycles(2);
      printf("\r\n\n  %lu karakter girin: ",s1_char_size);
      get_line1();
    delaycount=2; //-------> tarama hızı burdan ayarlanıyo..
    while (delaycount)
      col_index = startposition % 6;
      char_index = startposition / 6;
      if (char_index >= sizeof(s1))
        startposition = 0;
        char_index = 0;
        col_index = 0;
      x = s1[char_index];
// 74HC595 ler suruluyor
      output_high(PIN_SH_CP);
      output_high(PIN_ST_CP);
      output_high(PIN_SER_IN);
      output_low(PIN_SH_CP);
      delay_us(1);
      output_low(PIN_SER_IN);
      for (i=0;i<80;i++) // 80 tane kolon kullanıyoruz
        //port_b=0;
        output_low(PIN_ST_CP);
        delay_us(200);
        delay_us(1);
        delay_us(1);
        if (col_index == 5)
          col_index = 0;
          char_index++;
            char_index = 0;
          x = s1[char_index];
        else
          if ( x < 32)
            HC595_OUT_satir(0);
          else if( x < 64)
            HC595_OUT_satir(ascii1[x-32][col_index]);
          else if( x < 96 )
            HC595_OUT_satir(ascii2[x-64][col_index]);
          else if( x < 128)
            HC595_OUT_satir(ascii3[x-96][col_index]);
          col_index++;
        delay_us(120);
        HC595_OUT_satir(0);
      delaycount--;
    startposition++;
  } while(true);
multimeter with 16f877
What can We Do ???
PBP stands for 'pic basic pro' and it means that the code was written using picbasic pro language and need to be compiled with pbpw.exe or pbp.exe
thats all i can afford to help.
good luck
matrix led 6432 pic18
Yeeeeeeeeeees i'm very in need to that project
i Need Led Matrix with 877a with moving massage
All what i found move the letter from firest 5X7 to second 5X7 to third 5X7 .. it look like Litter Shift from first block to another
Pleas attache your project Eng.ilker_32
led matrix 18f452
i'm Not Student ... i'm Communcation Eng.
But 452 more Expinsive than 877a .. When we need this project in Industerial perpuse it will be expinsive
Pleas help me using 877a to Get Moving massage
Added after 3 minutes:
Eng,ilker_32
when I use Your Code this error Appears
18f452
The 18F4620 (an upgraded 18F452) is not much more than a 16F877A in quantity and it doesn't need an external oscillator.
Since this is not a school project you should consider hiring a consultant as the coding seems to be beyond your companies skill.
Do you really expect someone to write it for free, do they get a royalty on units sold?
PS nice "c rack" directory in your screen caps :)
16f887 datasheet
sorry, my english is bad. And i love a swedish girl. For this, i'm learning english new.
it is not MikroC, :D
you will use the CCS C.
OK.
  • kayan_yaz__305__877_6.9_sp4_8215.rar
ccs 18f452
It's Really wonderful marvelous superb gorgeous project ... it's actual touchs My purpose .. But it needs Very Very Small Modification ... That it Needs to LOOP the words ,, When the written sentence Ends it display DOTs .. But it must LOOP the
sentence agine and agine
Added after 1 hours 15 minutes:
Added after 3 hours 38 minutes:
Yasterday I Designed this Program to Enables users to Creat Custum char.
Just For You (( ilker_32 ))
I hope you enjoy it
  • led_matrix_custom_char._877a_1215.rar
Reactions: jito79
    jito79
8x8 led matrix 16f877a
thanks :D
i can make mistake the while writing. Please correct.
smsm3650, can do change the source code.
i'm not using ascii software. And for pratical,
//////////////////////////////////////////////////////////////////////////////////////////1
//////////////////////////////////////////////////////////////////////////////////////////2
//////////////////////////////////////////////////////////////////////////////////////////3
//////////////////////////////////////////////////////////////////////////////////////////4
//////////////////////////////////////////////////////////////////////////////////////////5
1=5
2=4
3=3
4=2
5=1
  • binhex2_2078.rar
  • 5x7_karakter_kodlay__305_c__305__2056.rar
  • base_converter_deci.hexdes.binar._evir_2470.rar
  • glcd_font_creator.v1.0.1_pro_2004.rar
  • ascii_haz__305_rlama_4060.rar
18f452 multimeter
Thank'ssssssssssssssss for All ... But the Word ("Sofie & ilker") do LOOP Only after 80 characters
And display Dot's
i tried to change the code
for(i=0; i<79; i++)
s1 = 46;
to
for(i=0; i<79; i++)
s1 = msg_default;
Or
for(i=0; i<sizeof(msg_default) ; i++)
s1 = msg_default;
But it failure ... Pleas Help Me to make the code Calculate (sizeof(msg_default)) and Loop it Automaticly
74hc595 + 18f
sorry, i had work. I could enter to the web page today. :D
sorry man :D
#include <16F877.H>
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
long s1_char_size=26;
char s1[26];
long i;
        output_high(data);
      else
        output_low(data);
      output_high(clock);
      delay_us(1);
      output_low(clock);
   output_high(latch);
   delay_us(1);
   output_low(latch);
    if(kbhit())
      s1[i]=getc();
      delay_cycles(2);
      printf("%C",s1[i]);
      delay_us(1);
    else
      i -= 1;
const char   msg_default[26] = "sofie & ilker"; // Yazdığınız cümle 80 karakterden küçük olduğu için kalan alan noktalar ile doldurulur.
/*"sofie & ilker" -> 13 karakter 26 - 13 = 13 boºluk*/
   {0b00000000, //   0
    0b00000000,
    0b00000000,
    0b00000000,
    0b00000000}
   {0b00000000, //   1
    0b00000000,
    0b01011111,
    0b00000000,
    0b00000000}
   {0b00000000, //   2
    0b00000111,
    0b00000000,
    0b00000111,
    0b00000000}
    0b01111111,
    0b00010100,
    0b01111111,
    0b00010100}
    0b00101010,
    0b01111111,
    0b00101010,
    0b00010010}
    0b00010101,
    0b01101011,
    0b01010100,
    0b01110010}
   {0b00110110, //   6
    0b01001001,
    0b01010110,
    0b00100000,
    0b01010000}
   {0b00000000, //   7
    0b00001011,
    0b00000111,
    0b00000000,
    0b00000000}
    0b00011100,
    0b00100010,
    0b01000001,
    0b00000000}
    0b01000001,
    0b00100010,
    0b00011100,
    0b00000000}
   {0b00101010, //   10
    0b00011100,
    0b01111111,
    0b00011100,
    0b00101010}
    0b00001000,
    0b00111110,
    0b00001000,
    0b00001000}
    0b01011000,
    0b00111000,
    0b00000000,
    0b00000000}
    0b00001000,
    0b00001000,
    0b00001000,
    0b00001000}
   {0b00000000, //   14
    0b01100000,
    0b01100000,
    0b00000000,
    0b00000000}
    0b00010000,
    0b00001000,
    0b00000100,
    0b00000010}
    0b01010001,
    0b01001001,
    0b01000101,
    0b00111110}
    0b01000010,
    0b01111111,
    0b01000000,
    0b00000000}
    0b01001001,
    0b01001001,
    0b01001001,
    0b01000110}
    0b01000001,
    0b01001001,
    0b01001001,
    0b00110110}
    0b00010100,
    0b00010010,
    0b01111111,
    0b00010000}
    0b01000101,
    0b01000101,
    0b01000101,
    0b00111001}
    0b01001010,
    0b01001001,
    0b01001001,
    0b00110000}
   //   26
        //      9
          //      27
          //      29
  //   0
//   9
//   12
//   27
//   29
   {2,1,2,4,2}     //   30
    0b10000010,
    0b10000010,
    0b10000010,
    0b01111101,
void main(void)
  int char_index;
  int col_index;
  int x = 0;
  long MSD, LSD;
  int delaycount;
  set_tris_b(0);
  set_tris_c(0x40);
  set_tris_d(0);
  HC595_OUT_satir(0);
  output_c(0);
  startposition = 0;
  //for(i=0; i<79; i++)
  //s1[i] = 46;
    s1[i] = msg_default[i]; i=0;
  delay_ms(100);
  do
      do
        delay_cycles(2);
        printf("\f\r\n");
        MSD=getc();
        delay_cycles(2);
        printf("%C",MSD);
        delay_us(1);
      do
        LSD=getc();
        delay_cycles(2);
        printf("%C",LSD);
        delay_us(1);
      delay_cycles(2);
      get_line1();
    while (delaycount)
        startposition = 0;
        char_index = 0;
        col_index = 0;
      x = s1[char_index];
      delay_us(1);
        //port_b=0;
        delay_us(200);
        delay_us(1);
        delay_us(1);
        if (col_index == 5)
          col_index = 0;
          char_index++;
            char_index = 0;
          x = s1[char_index];
        else
          if ( x < 32)
            HC595_OUT_satir(0);
          else if( x < 64)
          else if( x < 96 )
          else if( x < 128)
          col_index++;
        delay_us(120);
        HC595_OUT_satir(0);
      delaycount--;
    startposition++;
  } while(true);
OK!
Added after 11 minutes:
smsm3650,
where are you from :?:
AND, TEACH ME ENGLISH!!! :D
