schematic tracer in simvision
kadhan
Junior Member level 2
simvision design browser
How can we see the schematic of a verilog code in simvision.?
Regards,
Kad.
Regards,
Kad.
if you want view only schematic you can try to use rtl-compiler, for example: rc +gui [verilog-file].
but how you can compile your project and load it into simvision i don't know.
You can select a signal either in the design browser or in the waveforms window. Then press the schematic browser window, A schematic window will open showing the portion of the schematic having the signal that you have selected. In order to expand the schematic , double-click on any net in order to show all blocks connected to it.
    kadhan
Ok... it works...
Thanks for ur reply....
