Sample and Hold Circuit, cant get the same waveform!
syee10
Member level 3
Malaysia
Hi all,
I am designing a simple sample and hold circuit where the input is a sinusoidal analog input and it is control by a TTL compatible square wave (waveform A). The result waveform i should get is waveform B in the attach file but i tried a millions time i still cant get the same waveform. Someone there can help me out? I had attached all the file in the attachment..
Re: Sample and Hold Circuit Help!!
You mean a problem in simulation or in the real circuit? What's the observed waveform? What's the voltage at the (COM) node?
Can you post the DSN files?
I mean simulation not practically testing the circuits...
  • Part7.rar
When the switch is OFF the gate of the FET is floating. The gate needs to go somewhere.
Keith.
Yes. Gate bias of a JFET is a bit more complicated than of a MOSFET. You would connect a voltage divider (equal resistors) from U1A and U1B output to the gate to set the FET on state voltage and apply negative supply voltage V- to the gate to switch it off.
I dun really understand wat you mean..perhaps u can draw me a connection XD
I guess FvM means like this. It doesn't actually work like the diagram you showed, but that is because your circuit doesn't work on the negative half of the sine wave - this one does.
Keith.
  • Sample & Hold 2.pdf
Yes exactly, thank you. The switch S1 can be also replaced by a diode (anode at the gate), setting the control voltage to a negative polarity.
Can i know what kind of switch (S1) you are using? Why is there a ground at the switch?
I have had the "pleasure" of designing a JFET based S/H
product once.
The key is to ensure that when "on" the JFET switch gate
is roughly at the sampled signal potential, and when "off"
it is pinched off as little as possible, beyond "what works"
so you minimize charge injection and sampling pedestal.
I did this with a secondary follower amp (following both
sides of the switch, because pinchoff needs to comprehend
both and you don't know beforehand or during subsequent
input deviation during hold, which). The gate switched
between min(VIN,VHOLD) and min(VIN,VHOLD)-VPset (a
PJFET process).
You could of course pinch it more severely but that makes
the Qgate and sampling pedestal common-mode-sensitive.
It is a voltage controlled switch. It has two input terminals and two output terminals. I guess it is a bit like a relay in that respect. The ground node is there because otherwise the switch would be floating.
Keith.
The voltage controlled switch is a simulation tool rather than representing a real component. You can set threshold voltage, Ron and Roff according to your requirements. Unlike a real switch, it has no voltage limitation or charge injection, you can use it for pA or kA as well.
keith,
Can you check whether is my connection correct in SH3? I need to get an output just like the waveform 'B' in SH1.The output of inverter U5 is my reference TTL square signal. The waveform in SH1 is only show the positive part of Y axis. What i should get is the signal being sampled when the signal 'A' in SH1 is positive and hold the signal when the signal 'A' in SH1 is negative. Then the output will be the waveform 'B' in SH1. The connection that i constructed in SH3 seems to be the opposite of what i want..
I also attached the DSN file of proteus..hope to get your reply soon. Thanks =)
  • Part8.rar
Simply remove the inverter U5, or add another one. That will reverse the sampling logic.
Keith.
Can the sample and hold circuit change some configuration? because i must place an inverter U5 at there to get the correct waveform..
Maybe the output of U2 isn't sufficient to drive your switch? Monitor the output of U2 and see. You can always edit the switch parameters. Bear in mind the switch is a "perfect" one. If you want to build this circuit you will need to find some circuitry to replace it.
Keith.
