puviarasu said:There is a very bad danger of fire if you tap directly from the car battery as it can supply huge current. it is better to use a protection fuse and a diode (in your ckt) and there is a possibility of getting voltage more than 12 v due ti charging ckt with some noises from the source so it is good practice to use a zener protection diode at the input with a series low resistance.
