mohamedtarek
Newbie level 1
i would be really grateful if someone could tell me what is wrong with this code
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
LIBRARY LPM;
USE LPM.LPM_COMPONENTS.ALL;
LIBRARY work;
USE work.ALL;
ENTITY similarity_indicator IS
PORT
alpha_1,beta_1,alpha_2,beta_2 : IN STD_LOGIC_VECTOR (11 downto 0);
CLK,reset : IN STD_LOGIC;
SI : OUT STD_LOGIC_VECTOR (11 DOWNTO 0);
carry_out : OUT STD_LOGIC
END similarity_indicator;
architecture struct of similarity_indicator IS
--signal declaration
Signal mult1_a, mult1_b, mult2_a, mult2_b, sqrt1_output, sqrt2_output, adder1_a, adder1_b, adder1_result, adder2_a, adder2_b, adder2_result,t1 : STD_LOGIC_vector (11 downto 0);
Signal mult1_result, mult2_result, sqrt1_input, sqrt2_input : STD_LOGIC_vector (23 downto 0);
Signal adder1_carryout, adder2_carryout : STD_LOGIC;
Signal sqrt1_remainder, sqrt2_remainder :STD_LOGIC_VECTOR (12 downto 0);
--state definition
Type state is (one, two, three, four, five, six, seven, eight);
Signal present_state, next_state :state ;
--multiplier declaration
COMPONENT lpm_mult
GENERIC (
lpm_hint : STRING := "DEDICATED_MULTIPLIER_CIRCUITRY=NO,MAXIMIZE_SPEED=5";
lpm_representation : STRING := "UNSIGNED";
lpm_type : STRING :="LPM_MULT" ;
lpm_widtha : NATURAL :=12 ;
lpm_widthb : NATURAL :=12 ;
lpm_widthp : NATURAL :=24
PORT (
dataa : IN STD_LOGIC_VECTOR (11 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (11 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (23 DOWNTO 0)
END COMPONENT;
--square root unit declaration
COMPONENT altsqrt
GENERIC (
pipeline : NATURAL :=3;
q_port_width : NATURAL :=12;
r_port_width : NATURAL :=13;
width : NATURAL :=24;
lpm_type : STRING :="altsqrt"
PORT (
remainder : OUT STD_LOGIC_VECTOR (12 DOWNTO 0);
radical : IN STD_LOGIC_VECTOR (23 DOWNTO 0);
q : OUT STD_LOGIC_VECTOR (11 DOWNTO 0);
clk : IN STD_LOGIC
END COMPONENT;
-- adder declaration
COMPONENT lpm_add_sub
GENERIC (
lpm_direction : STRING := "ADD";
lpm_hint : STRING := "ONE_INPUT_IS_CONSTANT=NO,CIN_USED=NO" ;
lpm_type : STRING := "LPM_ADD_SUB";
lpm_width : NATURAL := 12
PORT (
cout : OUT STD_LOGIC ;
result : OUT STD_LOGIC_VECTOR (11 DOWNTO 0)
END COMPONENT;
Begin
--portmapping of blocks
-- portmapping the multipliers
multiplier1:lpm_mult port map (mult1_a, mult1_b,mult1_result);
multiplier2:lpm_mult port map (mult2_a, mult2_b,mult2_result);
--portmapping the square root units
sqrt1:altsqrt port map (sqrt1_remainder,sqrt1_input,sqrt1_output,CLK);
sqrt2:altsqrt port map (sqrt2_remainder,sqrt2_input,sqrt2_output,CLK);
--portmapping the adder units
adder1:lpm_add_sub port map (adder1_a, adder1_b,adder1_carryout ,adder1_result);
adder2:lpm_add_sub port map (adder2_a, adder2_b,adder2_carryout ,adder2_result);
--process part
statesrocess (present_state)
Begin
--switch on the possible states to producs the required FSM
CASE present_state IS
WHEN one =>
mult1_a <= alpha_1;
mult1_b <= beta_1;
mult2_a <= alpha_2;
mult2_b <= beta_2;
next_state <= two;
WHEN two =>
mult1_a <= alpha_1;
mult1_b <= beta_1;
mult2_a <= alpha_2;
mult2_b <= beta_2;
sqrt1_input <= mult1_result;
sqrt2_input <= mult2_result;
next_state <= three;
WHEN three =>
mult1_a <= alpha_1;
mult1_b <= beta_1;
mult2_a <= alpha_2;
mult2_b <= beta_2;
next_state <= four;
WHEN four =>
next_state <= five;
WHEN five =>
adder1_a <= sqrt1_output;
adder1_b <= sqrt2_output;
next_state <= six;
WHEN six =>
t1 <= adder1_result;
next_state <= seven;
WHEN seven =>
adder2_a <= t1;
adder2_b <= adder1_result;
next_state <= eight;
WHEN eight =>
adder1_a <= adder1_result;
adder1_b <= adder2_result;
SI <= adder1_result;
carry_out <= adder1_carryout;
next_state <= one;
end CASE;
end process;
seq: Process (CLK, reset)
Begin
If (reset = '0') THEN
present_state <= one;
ELSIF (CLK'EVENT AND CLK = '1') THEN
present_state <= next_state;
END IF;
END process;
end struct;
LIBRARY ieee;
LIBRARY LPM;
LIBRARY work;
USE work.ALL;
PORT
--state definition
COMPONENT lpm_mult
GENERIC (
PORT (
END COMPONENT;
COMPONENT altsqrt
GENERIC (
PORT (
clk : IN STD_LOGIC
END COMPONENT;
GENERIC (
PORT (
END COMPONENT;
Begin
--process part
Begin
WHEN one =>
mult1_a <= alpha_1;
mult1_b <= beta_1;
mult2_a <= alpha_2;
mult2_b <= beta_2;
next_state <= two;
WHEN two =>
mult1_a <= alpha_1;
mult1_b <= beta_1;
mult2_a <= alpha_2;
mult2_b <= beta_2;
WHEN three =>
mult1_a <= alpha_1;
mult1_b <= beta_1;
mult2_a <= alpha_2;
mult2_b <= beta_2;
next_state <= four;
WHEN four =>
next_state <= five;
WHEN five =>
next_state <= six;
WHEN six =>
WHEN seven =>
adder2_a <= t1;
WHEN eight =>
next_state <= one;
end CASE;
end process;
Begin
END IF;
END process;
end struct;
