varunme
Advanced Member level 3
RTC interfacing with proteus, yeilds no display of time on lcd, didnt checked on real hardware
code used is
code used is
unsigned char sec, min1, hr, week_day, day, mn, year;
char *txt, tnum[3];
// LCD module connections
sbit LCD_RS at RD2_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_EN at RD3_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D4 at RD4_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D5 at RD5_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D6 at RD6_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D7 at RD7_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_RS_Direction at TRISD2_bit;
sbit LCD_EN_Direction at TRISD3_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
void Zero_Fill(char *value) { // fill text repesentation
if (value[1] == 0) { // with leading zero
value[1] = value[0];
value[0] = 48;
value[2] = 0;
//--------------------- Reads time and date information from RTC (DS1307)
void Read_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
I2C1_Start();
I2C1_Wr(0xD0);
I2C1_Wr(0);
I2C1_Repeated_Start();
I2C1_Wr(0xD1);
*sec =I2C1_Rd(1);
*min =I2C1_Rd(1);
*hr =I2C1_Rd(1);
*week_day =I2C1_Rd(1);
*day =I2C1_Rd(1);
*mn =I2C1_Rd(1);
*year =I2C1_Rd(0);
I2C1_Stop();
//-------------------- Formats date and time
void Transform_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
*sec = ((*sec & 0x70) >> 4)*10 + (*sec & 0x0F);
*min = ((*min & 0xF0) >> 4)*10 + (*min & 0x0F);
*hr = ((*hr & 0x30) >> 4)*10 + (*hr & 0x0F);
*week_day =(*week_day & 0x07);
*day = ((*day & 0xF0) >> 4)*10 + (*day & 0x0F);
*mn = ((*mn & 0x10) >> 4)*10 + (*mn & 0x0F);
*year = ((*year & 0xF0)>>4)*10+(*year & 0x0F);
//-------------------- Output values to LCD
void Display_Time(char sec, char min, char hr, char week_day, char day, char mn, char year) {
switch(week_day){
case 1: txt="Sun"; break;
case 2: txt="Mon"; break;
case 3: txt="Tue"; break;
case 4: txt="Wed"; break;
case 5: txt="Thu"; break;
case 6: txt="Fri"; break;
case 7: txt="Sat"; break;
LCD_Out(1,1,txt);
Lcd_Chr(1, 6, (day / 10) + 48); // Print tens digit of day variable
Lcd_Chr(1, 7, (day % 10) + 48); // Print oness digit of day variable
Lcd_Chr(1, 9, (mn / 10) + 48);
Lcd_Chr(1,10, (mn % 10) + 48);
Lcd_Chr(1,15, year + 48); // Print year vaiable + 8 (start from year 2008)
Lcd_Chr(2, 6, (hr / 10) + 48);
Lcd_Chr(2, 7, (hr % 10) + 48);
Lcd_Chr(2, 9, (min / 10) + 48);
Lcd_Chr(2,10, (min % 10) + 48);
Lcd_Chr(2,12, (sec / 10) + 48);
Lcd_Chr(2,13, (sec % 10) + 48);
//------------------ Performs project-wide init
void Init_Main() {
ADCON1 |= 0x0F; // Configure AN pins as digital
CMCON |= 7; // Disable comparators
I2C1_Init(100000); // Initialize Soft I2C communication
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD display
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
LCD_Chr(1,8,'.');
LCD_Chr(1,11,'.');
txt = "Time:";
LCD_Out(2,1,txt);
LCD_Chr(2,8,':');
LCD_Chr(2,11,':');
txt = "200";
Lcd_Out(1,12,txt);
LCD_Cmd(_LCD_CURSOR_OFF);
//----------------- Main procedure
void main() {
Init_Main(); // Perform initialization
while (1) { // Endless loop
Read_Time(&sec,&min1,&hr,&week_day,&day,&mn,&year); // read time from RTC(DS1307)
Transform_Time(&sec,&min1,&hr,&week_day,&day,&mn,&year); // format date and time
Display_Time(sec, min1, hr, week_day, day, mn, year); // prepare and display on LCD
Delay_ms(1000); // wait 1s
