RS232 search received text
This is untested code using Serial Interrupt for receiving data.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char myFlags = 0;
char uart_rd[50], buffer[20], str[17];
unsigned int index = 0, i = 0, j = 0, value = 0;
sbit Read at myFlags.B0;
sbit Convert at myFlags.B1;
void interrupt() {
     if(OERR1_bit) {
            OERR1_bit = 0;
            CREN1_bit = 0;
            CREN1_bit = 1;
     if(RC1IF_bit) {
          if(RC1REG == '=') {
                Read = 1;
                index = 0;
          if(RC1REG == '0') {
                Read = 0;
                COnvert = 1;
          if(Read) {
                uart_rd[index++] = RC1REG;
          RC1IF_bit = 0;
void main() {
     CM1CON0 = 0x00;
     CM2CON0 = 0x00;
     SLRCON = 0x00;
     ANSELA = 0x00;
     ANSELB = 0x00;
     ANSELC = 0x00;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0xC0;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     LATA = 0x00;
     LATB = 0x00;
     LATC = 0x00;
     Lcd_Init();                        // Initialize LCD
     Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
     Lcd_Cmd(_LCD_CLEAR);               // Clear display
     Lcd_Out(1,6,"Weight:");                 // Write text in first row
     UART1_Init(9615);
     Delay_ms(100);
     RC1IE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     RC1IF_bit = 0;
     while(1) {
             if(Convert) {
                     i = 0;
                     j = 0;
                     while(uart_rd[i] != '0') {
                              buffer[j++] = uart_rd[i++];
                     value = 0;
                     for(i = 0; i < j; i++, j--) {
                            value += (buffer[i] - 48) * 10^(j - 1);
                     IntToStr(value, str);
                     Ltrim(str);
                     strcat(str, " Kgs");
                     Lcd_Out(2,6,str);
                     Convert = 0;
It is a strange format but I would do it this way:
char ValueFound = 0;
char RxByte;
if (UART1_Data_Ready()) RxByte = UART1_Read();
if(RxByte == '=') ValueFound = 1;
if((RxByte != '0') && (ValueFound == 1)
	Lcd_Out_Cp(RxByte );
	UART1_Write(RxByte); // and send data via UART
else ValueFound = 0;
This might include the '=' but it should only output characters up to the first '0'.
It would be even simpler if interrupts were used!
Please note that I have not tried it and I use a different compiler here.
Brian.
Change this
Code C - [expand]
to
Code C - [expand]
value += (buffer[i] - 48) * pow(10, (double)(j-1);
betwixt's code is better than mine. Use his code.
Here is the code which I made.
Working code attached.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
char myFlags = 0;
char uart_rd[10] = "123000000", buffer[20], str[17];
sbit Display at myFlags.B1;
void interrupt() {
     if(OERR1_bit) {
            OERR1_bit = 0;
            CREN1_bit = 0;
            CREN1_bit = 1;
     if(RC1IF_bit) {
          if(RC1REG == '=') {
                Read = 1;
                index = 0;
          if(RC1REG == '0') {
                Read = 0;
                Display = 1;
          if(Read) {
               uart_rd[index] = '\0';
          RC1IF_bit = 0;
void main() {
     CM1CON0 = 0x00;
     CM2CON0 = 0x00;
     SLRCON = 0x00;
     ANSELA = 0x00;
     ANSELB = 0x00;
     ANSELC = 0x00;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0xC0;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     LATA = 0x00;
     LATB = 0x00;
     LATC = 0x00;
     UART1_Init(9615);
     Delay_ms(100);
     RC1IE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     RC1IF_bit = 0;
     while(1) {
            if(Display) {
                  LCD_Out(2,1,uart_rd);
                  Display = 0;
  • uart2lcd.rar
Our code will probably work the same. My code is strange because I'm not a software engineer. I also don't use MikroC, I only toy with it.
We both mixed literals with text, it might need to be corrected. The Lcd_Out_Cp puts text at the cursor and after reaching the end of line the data is lost, so it needs correcting too. Well, we have to leave some for him to do.
If you still want the integer value to do some calculation then you can do like this.
Code C - [expand]
value = atoi(uart_rd);
Thanks a lot for your help to both of you, I will test it in hardware then report back to you.
Here is a better code than my previous code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
char myFlags = 0;
void interrupt() {
     if(OERR1_bit) {
            OERR1_bit = 0;
            CREN1_bit = 0;
            CREN1_bit = 1;
     if(RC1IF_bit) {
          if((RC1REG != '0') && (Read == 1))  {
          else if(RC1REG == '=') {
                Read = 1;
                index = 0;
          else if(RC1REG == '0') {
                 Display = 1;
          RC1IF_bit = 0;
void main() {
     CM1CON0 = 0x00;
     CM2CON0 = 0x00;
     SLRCON = 0x00;
     ANSELA = 0x00;
     ANSELB = 0x00;
     ANSELC = 0x00;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0xC0;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     LATA = 0x00;
     LATB = 0x00;
     LATC = 0x00;
     UART1_Init(9615);
     Delay_ms(100);
     RC1IE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     RC1IF_bit = 0;
     while(1) {
            if(Display) {
                  Display = 0;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
char myFlags = 0;
void interrupt() {
     if(OERR1_bit) {
            OERR1_bit = 0;
            CREN1_bit = 0;
            CREN1_bit = 1;
     if(RC1IF_bit) {
                Read = 1;
                index = 0;
                 Display = 1;
          RC1IF_bit = 0;
void main() {
     CM1CON0 = 0x00;
     CM2CON0 = 0x00;
     SLRCON = 0x00;
     ANSELA = 0x00;
     ANSELB = 0x00;
     ANSELC = 0x00;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0xC0;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     LATA = 0x00;
     LATB = 0x00;
     LATC = 0x00;
     UART1_Init(9615);
     Delay_ms(100);
     RC1IE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     RC1IF_bit = 0;
     while(1) {
            if(Display) {
                  Display = 0;
It seems that neither PIC16F877 nor PIC18F452/0 SUPPORT serial interrupt, I couldn't test this code since I don't have the PIC used in compiling and it's not available where I live
char RxByte;
Brian.
It didn't work, Once I enter = sign it keeps writing the same sign on screen and don't get the numbers after
here is the code
sbit LCD_RS at RB1_bit;
sbit LCD_EN at RB0_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB1_bit;
sbit LCD_EN_Direction at TRISB0_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
int i;
char txt1[] = "=test";
char receive[20];
char uart_rd;
void main()
  Lcd_Out(1,6,txt1);                 // Write text in first row
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize
UART1_Write_Text("Start");
UART1_Write(10);
UART1_Write(13);
while (1)
{ // Endless loop
char RxByte;
if(RxByte == '=') {ValueFound = 1;} else {ValueFound = 0;}
 delay_ms(10);
if((RxByte != '0') && (ValueFound == 1))
You have missed my code on post #20 , it shouldn't get stuck displaying =
ALL PICs support serial interrupt. Show me where you found this wrong information.
If you use interrupts it makes life much easier, you can write a simple routine that is called each time a character arrives at the UART, there is no need to keep looking to see if the UART is ready and you do not need the loops which hold up the rest of the program. There is a real danger at the moment that while doing other things, for example writing to the LCD, you miss an incoming character altogether. With interrupts that doesn't happen.
I should add that the changes you made to my code are guaranteed to stop it working!
Brian.
ALL
Brian.
Hi Brian,
kobre98 missed the else condition in your code, this is why the = is repeated.
Look carefully at your code, it lets displaying the = as it appears in the uart. What is missing is waiting for the next uart input and displaying it if it isn't zero.
I also didn't notice this problem when I looked at your code.
I'm sure you can fix it.
Did you try this code ?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
char myFlags = 0;
char uart_rd[10], buffer[20], str[17];
unsigned int index = 0, value = 0;
void interrupt() {
     if(OERR1_bit) {
            OERR1_bit = 0;
            CREN1_bit = 0;
            CREN1_bit = 1;
     if(RC1IF_bit) {
          if((RC1REG != '0') && (Read))  {
                Read = 1;
                index = 0;
                 Display = 1;
          RC1IF_bit = 0;
void main() {
     CM1CON0 = 0x00;
     CM2CON0 = 0x00;
     SLRCON = 0x00;
     ANSELA = 0x00;
     ANSELB = 0x00;
     ANSELC = 0x00;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0xC0;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     LATA = 0x00;
     LATB = 0x00;
     LATC = 0x00;
     UART1_Init(9615);
     Delay_ms(100);
     RC1IE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     RC1IF_bit = 0;
     while(1) {
            if(Display) {
                  Display = 0;
You didn't tell what happens if weight is 40 or 400 kgs. It will get displayed as 4 kgs.
Vbase, I intended the new code to be a drop in for the code inside the while() loop in the original. It would still have one deficiency, it would stop on the first zero character even if it was between other digits.
The best way is to use interrupts, capture everything between each '=' to a buffer, trim all the trailing zero characters (like Ltrim but using '0' instead of spaces) then convert the result to a number. I can write it easily in my compiler but Mikro is not fully ISO compliant and it has some strange library functions. I'm not sure how portable it would be.
Brian.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
char myFlags = 0;
void interrupt() {
     if(OERR1_bit) {
            OERR1_bit = 0;
            CREN1_bit = 0;
            CREN1_bit = 1;
     if(RC1IF_bit) {
                Read = 1;
                index = 0;
                 Display = 1;
          RC1IF_bit = 0;
void main() {
     CM1CON0 = 0x00;
     CM2CON0 = 0x00;
     SLRCON = 0x00;
     ANSELA = 0x00;
     ANSELB = 0x00;
     ANSELC = 0x00;
     TRISA = 0xC0;
     TRISB = 0x00;
     TRISC = 0xC0;
     PORTA = 0x00;
     PORTB = 0x00;
     PORTC = 0x00;
     LATA = 0x00;
     LATB = 0x00;
     LATC = 0x00;
     UART1_Init(9615);
     Delay_ms(100);
     RC1IE_bit = 1;
     PEIE_bit = 1;
     GIE_bit = 1;
     RC1IF_bit = 0;
     while(1) {
            if(Display) {
                  Display = 0;
After hitting compile I get these messages
26 324 Undeclared identifier 'OERR1_bit' in expression MyProject.c
28 324 Undeclared identifier 'OERR1_bit' in expression MyProject.c
29 324 Undeclared identifier 'CREN1_bit' in expression MyProject.c
30 324 Undeclared identifier 'CREN1_bit' in expression MyProject.c
33 324 Undeclared identifier 'RC1IF_bit' in expression MyProject.c
34 324 Undeclared identifier 'RC1REG' in expression MyProject.c
35 324 Undeclared identifier 'RC1REG' in expression MyProject.c
39 324 Undeclared identifier 'RC1REG' in expression MyProject.c
43 324 Undeclared identifier 'RC1REG' in expression MyProject.c
47 324 Undeclared identifier 'RC1IF_bit' in expression MyProject.c
53 324 Undeclared identifier 'CM1CON0' in expression MyProject.c
54 324 Undeclared identifier 'CM2CON0' in expression MyProject.c
56 324 Undeclared identifier 'SLRCON' in expression MyProject.c
58 324 Undeclared identifier 'ANSELA' in expression MyProject.c
59 324 Undeclared identifier 'ANSELB' in expression MyProject.c
60 324 Undeclared identifier 'ANSELC' in expression MyProject.c
70 324 Undeclared identifier 'LATA' in expression MyProject.c
71 324 Undeclared identifier 'LATB' in expression MyProject.c
72 324 Undeclared identifier 'LATC' in expression MyProject.c
83 324 Undeclared identifier 'RC1IE_bit' in expression MyProject.c
86 324 Undeclared identifier 'RC1IF_bit' in expression MyProject.c
0 102 Finished (with errors): 26 Apr 2015, 18:36:10 MyProject.mcppi
Yes, you get that error because you are using a different PIC than the one I used. I used PIC18F26K22. It has 2 UART. Your PIC has only one UART. So you have to use these
OERR_bit
CREN_bit
RCIF_bit
RCREG
RCIE_bit
and
if you are using PIC16F then replace LATx with PORTx
Also for your PIC maybe there is ANSEL / ANSELH / CMCON / ADCON1. So, if you zip and post your complete mikroC project then I will fix the code according to your PIC by looking at the datasheet.
You can also set the proper registers. All you have to do is disable comparators (not needed for your project) and make all IO pins as digital IO.
This is in addition to your code.
It reads every char that comes in and if it isn't 0 after the = it puts it on the LCD and sends it to UART.
sbit LCD_RS at RB0_bit;
sbit LCD_EN at RB1_bit;
sbit LCD_RS_Direction at TRISB0_bit;
sbit LCD_EN_Direction at TRISB1_bit;
char uart_rd;
void main()
UART1_Write(10);
UART1_Write(13);
while (1)
{ // Endless loop
if (UART1_Data_Ready()) { // If data is received,
uart_rd = UART1_Read(); // read the received data,
if(uart_rd=='='){
          if(uart_rd){             //if digit after = not zero
              Lcd_Out_Cp(uart_rd);
              UART1_Write(uart_rd); // and send data via UART
It didn't work either ! it displayed nothing on LCD except for the test word
OERR_bit
CREN_bit
RCIF_bit
RCREG
RCIE_bit
and
attached my test
  • eda.zip
Fixed code attached.
  • eda.rar
Brian.
Brian,
That is right MicroC isn't portable. They use libraries for everything to make it easy to write a code, of course libraries have limited options. If you compile with it a code that was written in MPLAB for MCC18 you get only a few errors.
Using interrupt is a little complicated for beginners but it is ok if they write imperfect code.
Thanks a lot, I tested this code using Proteus and hardware, in Proteus everything works fine, but when I turn to hardware since I receive continuous non stop feed of this format =000240=000090=000088= ...etc
It display things very fast on the LCD in such a way that it display unknown characters, I want this code to display 10 or 20 reading then stop getting readings.
It's not just one value, and it doesn't depend on zeros I need it to read the value between the two "=" signs, and display it on LCD.
LCDs tend to be very slow devices compared to the execution speed of modern microcontrollers so one requires delays between writing characters otherwise it displays rubbish
for example, on a Bytronic PIC24 trainer
using a PIC24FJ256GB110 I find the following works OK
void lcdNibble(int n)
    int lcd=LCDdata;
//	lcd_delay();
	__delay_us(800);
  	LCDdata = (lcd&0xfff0) | ((n & 0x0f));			// send out lower Nibble
	//lcd_delay();
// 	__delay_us(1);
  	Nop();					// Wait E Pulse width time (min 230ns)
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
  LCDstatus.E=1;					// take clock E high
// 	__delay_us(1);
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	//lcd_delay();
    LCDstatus.E=0;
 	__delay_us(800);
	//lcd_delay();
note the delay when changing the enable pulse level and the 800 microseconds delay at the end of the function (before attempting to write the following character)
the delay values will depend on the LCD and processor execution speed and in practice one has to try values until it works Ok with the minimum delay
