ddrdan
Newbie level 1
I have an invention. I need a small motor that will rotate a 3/8" dia. alum. rod 30 degrees when I push a button. I prefer a sleeve connection and not threaded.
Torque req'd is less than 1 pound. Voltage would be a 120v adapter with what ever the motor requires. Parameters are 2.5" wide x 2.5" long and height can be up to 6". The motor shaft will be parallel to the height.
I've searched the web, but I don't have the tech knowledge for describing what I'm looking for. I've been using "electromagnetic motor . servo".
Thanks for any help
Thanks for any help
