Tonibco
Newbie level 5
Hi all,
I´m actually checking the Bluetooth connectivity among the RN42 BT card (as a Master) and HC06 card (as a slave). I´m using Coolterm platform in order to register the RN42 commands to manage the connectivity. It seems everything is working properly using different commands, until I entry the BT connectivity command (C,<address>), which it indicates the connection is done (at least I think so) like:
TRYING
conn
CONNECT,201307182757,0
and then the platform is blocked, so that I cannot entry any other command...since I am not able to do anything, unless I reset the Coolterm platform as well as plug out and in the USB cables, power supply, so on...
What can I do? Could you please help me with it?
Many thanks,
Toni
TRYING
conn
Many thanks,
Toni
