LaughingMAN
Newbie level 6
I'm confused about the 50ohm load in the RF Power Amplifier. My questions are:
1. In simulation, I usually put in the 50ohm load, but when you do the actual design, do you omit out the load and replace it with an external load to do measurement? What would happen if you don't put in the load?
2. Most instruments such as PNA says that it is terminated with a 50ohm load, does that mean that I don’t need a external load when doing s parameter measurement?
3. I have seen most people using attenuator at the output of Power Amplifier to do measurements, is the attenuator similar to a 50ohm load but with power attenuation?
4. The RF power meter has a power sensor, which can dissipate power, so do I need an external load as well?
Any help would be much appreciated.
