gmish27
Member level 1
Hi all,
I have implemented a 2-stage pipelined architecture of JPEG-2000 encoder and would want you to give your views about the same. The maximum speed achieved is 37.485MHz. Some of the details I have listed below:
1. I have not used multipliers at all, so that the architecture can be dumped on any FPGA platform, even one without a dsp slice.
2. The hardware takes 64 clk cycles in order to encode an 8x8 block of image with the given clk frequency.
Final Results
RTL Top Level Output File Name : feed.ngr
Output Format : NGC
Optimization Goal : Speed
Keep Hierarchy : NO
Design Statistics
# IOs : 10
Cell Usage :
# BELS : 48861
# GND : 2
# INV : 402
# LUT1 : 57
# LUT2 : 13342
# LUT3 : 2619
# LUT4 : 329
# LUT5 : 311
# LUT6 : 1016
# MUXCY : 15969
# MUXF7 : 20
# VCC : 2
# XORCY : 14792
# FlipFlops/Latches : 1056
# FDC : 32
# FDCE : 512
# FDE : 512
# RAMS : 1
# RAMB18 : 1
# Clock Buffers : 1
# BUFGP : 1
# IO Buffers : 9
# IBUF : 1
# OBUF : 8
Device utilization summary:
Selected Device : 5vlx110tff1136-1
Slice Logic Utilization:
Number of Slice Registers: 1056 out of 69120 1%
Number of Slice LUTs: 18076 out of 69120 26%
Number used as Logic: 18076 out of 69120 26%
Slice Logic Distribution:
Number of LUT Flip Flop pairs used: 18515
Number with an unused Flip Flop: 17459 out of 18515 94%
Number with an unused LUT: 439 out of 18515 2%
Number of fully used LUT-FF pairs: 617 out of 18515 3%
Number of unique control sets: 68
IO Utilization:
Number of IOs: 10
Number of bonded IOBs: 10 out of 640 1%
Specific Feature Utilization:
Number of Block RAM/FIFO: 1 out of 148 0%
Number using Block RAM only: 1
Number of BUFG/BUFGCTRLs: 1 out of 32 3%
Timing Summary:
Speed Grade: -1
Minimum period: 26.726ns (Maximum Frequency: 37.417MHz)
Minimum input arrival time before clock: 3.567ns
Maximum output required time after clock: 6.560ns
Maximum combinational path delay: No path found
# Adders/Subtractors : 954
# Counters : 1
# Registers : 140
# Comparators : 3
# Multiplexers : 1
