celebrevida
Member level 2
I am needing to generate somewhat precise voltage references. I have access to 1.5V.
I need the following references:
0.75V
0.807V to 0.969V in 0.0108V steps (so 16 references in total)
I am considering these two options using poly resistors:
1) From vss to vref0p75: 375k resistor (actually 10*37.5k in series)
From vref0p75 to vref0p807, a 28.5k resistor
From vref0p807 to vref0p969, (15*5.3756k resistors in series, each tap represents the 16 references)
From vref0p969 to vref1p5, 265.9k resistor (actually 10*26.59k in series)
(Total resistances=750k to limit Iload to ~2uA)
This gives me exactly the references I need to within 1mV.
But by using an assortment of different resistors, I wonder how well this works over process variation.
2) From vss to vref1p5, use 128*5.847k resistors in series. Then choose the taps closest to what I need.
For the vref0p75, this works, I simply access the middle tap. But for the other 16, it doesn't exactly line up and I can be as much as 10mV off. However, by using 128 unit resistors, perhaps this might actually a better choice than (1) due to less process variation?
What is the best choice for resistor ladder design to get closest to the voltage references I want over process variation?
And is there a third scheme that is better than either that I should consider?
Thanks!
0.75V
Thanks!
