F-Moura
Junior Member level 2
Hi people,
I´m working at a circuit with MCP73831, this IC is a "Miniature Single-Cell, fully Integrated Li-Ion, Li-Polymer Charge Management Controllers". My electronic will be used in industrial application, in an area with flamable gaz. Therefore, in Brazil, there is a standard. In this case I need use resin in my circuit.
The MCP is sensitive to temperature, in the datasheet is informed that the circuit need a copper area to dissipe heat.
I can use resin for this circuit? There are any resin for power supply ?
tnx very much
tnx very much
