Replacement of PAM8406DR for Class AB audio Amplification
Heena09
Junior Member level 3
Hello All,
I am using PAM80406DR IC for Audio amplification But its size is bit high . I a using it with Analog mems MIC of CUI devices for amplification
Now i wants to replace this PAM8406DR with AB amplification. But not yet find out any.
class AB amplifiers in the same range of output power may easily need a heatsink in the size of a cigarette box...
Klaus
Y
Klaus
Thank you,
So that i need to replace it for Proper Audio amplification.
Any suggestion
Please explain your application. What's the point of connecting a 2x5 W class D power amplifier to a microphone?
I am interfacing mic to send an audio via Bluetooth so the quality of PAM8406DR CLASS AB is very good but need to reduce the size on PCB. ANd need good replacement IC
Your thinking is wrong.. You don't need Power Amplifier, you just need a Microphone Amplifier.
Bluetooth module should normally have kOhm range Input Impedance. You cannot drive this impedance by power amplifier.
