Replacement diode for RK46 diode from SI-8033S
cool.man
Full Member level 6
Earth
I was previously using 3.3v regulator (LM2937ET).But now unfortunetly it is short in local market and i come across new regulator (SI-8033S).It has a recommended circuit which consist of a diode (RK46),inductor (150uH) and capacitors.
Unfortunetly diode (RK46) is unavailable in the local market.Can anyone tell me is there any replacement diode which i can use.The manufacturer recommend in the datasheet to use (RK46).Following is the circuit diagram and the recommendation note.
Re: 3.3v Regulator query
You can use almost any Shottky rectifier. The important parameter is speed, most normal rectifiers (1N400x series for example) are not fast enough. The voltage and current in your circuit will be quite low. I use 1N5819 in this sort of application.
Brian.
Thanks guys for your help.I am using 1N5819,Is there any way to find that this diode will work fine with SI-8033S.
you see,
RK46 (60V,3.5A, Trr100nsec Schottky) has ca. 0.6V at 3A, 1N5819 has 0.9V at 3A and (for me) are speed data unknowed!
Trr can be relevant in your appl, another question is the 50% higher voltage drop, it can be a problem too, but (I think) will not kill the SI-8033 :)...
K.
