XR2STEVEB
Newbie level 1
- Joined
- Mar 7, 2010
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- portsmouth
- Activity points
- 1,284
Re: relay triggering
how did you alter it to 5 seconds mate as i want to do similar to this for something i am doing cheers stevejojoe said:Sorry I don't have a data sheet on the relay....it is a Ford heated rear window timer relay...the way it would normally work would be that when you press the button on the dash of your Ford to switch the heated rear window on the relay energises....approx 10 minutes later it switches off.
I have altered the resistor / capacitor timing arrangement inside of the relay so that it is only energises for 5 seconds, after 5 seconds the relay switches off (to the position it would be in with no power applied to it at all).
