maydayone
Newbie
Hello,
I have an electric hob which appears to have a problem with a relay. Every time I want to use it, I need to turn off the power and turn it back on. Then when I try to use it I can hear a click when the relay comes on and it works fine. But when I want to use it again, let's say an hour later, it won't click on. Even though the power is set to max, there is no click on the relay and no heat. What fixes it is to completely power it off(disconnect the power to it), and power it back on. Works every time. Can anyone suggest/ confirm if this is indeed a relay fault or possibly something else? Thank you.
