FreshmanNewbie
Full Member level 6
I'm using this Battery charger IC.
What does it mean when one says, "The OUT pins do not offer regulation"?
For example, if the part has a VREG of 4.2V, the IC charges the battery to Vbat. That is Ok. What about the OUT pins? What would be the voltage at the OUT pins when the input supply IN pin is at 5V? And it is said that the OUT pins do not offer regulation?
Does it mean that the OUT pins would provide the same input 5V and provide 4.2V to VBAT pins? But as per the function diagram, there's a pass MOSFET. How to understand this?
