REgarding USer interactive menu flow Help
cnandha19
Member level 3
Here i attached the model of menu flow i had the menu flow with 1 press means it goes to 1 st Menu 1.Company name and again '1' pressed means it goes to company address but i wanna to change it 1 pressed means it goes to company address after the enter pressed means it has to goto company address and if i am in company address if Esca pressed means it goes back to companyname i want logic please help me
    while(1)
	key =READ_SWITCHES();
   case '1' :
         ///SET KEY
						switch(mode)
							case mCompanyname:
								key = companyname_function();
								if(key)
							        lcdClear();
							        lcdMoveCursor(0,0);
							        lcdPrintStr("1.Company details");
							        lcdMoveCursor(1,0);
							        lcdPrintStr("2.Calibration off");
							        lcdMoveCursor(2,0);
							        lcdPrintStr("3.Set date time");
							        lcdMoveCursor(3,0);
							        lcdPrintStr("4.Manage userpass");
								menu = mpassword;
								mode = mCompanyAddress;    //mcalibration
								else
									menu = mpassword;
							break;
							case mCompanyAddress:
								key = company_address();
								if(key)
									lcdClear();
									lcdMoveCursor(0,0);
									lcdMoveCursor(1,0);
									lcdMoveCursor(2,0);
									lcdMoveCursor(3,0);
									menu = mpassword;
									mode = mcalibration;    //mcalibration
								else
									menu =mpassword;
							break;
I normaly do something like this
typedef struct { u8 MenuID, bool EnterFlag, bool ** Handler (bool EnterFlag)} MenuTypeDef;
than we just loop it
while (1) Menu.EnterFlag = Handler[Menu.MenuID].Handler (Menu.EnterFlag);
when it goes to handler, it resets EnterFlag and update screen
when it goes to another handler, it sets EnterFlag and let another handler update the screen data
So, basicaly, only one string are used.
while (1) Menu.EnterFlag = Menu.Handler[Menu.MenuID].Handler (Menu.EnterFlag);
sorry, small mistake. Handler is also part of menu structure.
