sakibnaz
Full Member level 3
Hi there.
I am working on a project which will be Li-Po 1-Cell Battery (6Ah) powered device. My project have ARM CPU hence it need 5V to run. For Battery Charging I like to implement USB Type-C 15W (5V, 3A) Charging system.
Now my device size needs to be small hence I am looking for if there any suitable High Efficiency 5V Boost Converter IC which integrated with 3A Charge Controller?
Initially I chooses TPS61232 Boost Converter (96% Efficiency) and there are many 3A Supported Switching Charge Controller which I can use. But if there any Boost Converter (High Efficiency and support around 2A) and Charge Controller (3A) Combo IC that will be best.
If anyone know ... please suggest.
Thanks in advance.
Regards.
Thanks in advance.
Regards.
