Reducing noise in buck converter powering push pull inverter
Bruno5234
Newbie level 5
Newbie level 5
Hi, I designed a buck converter that powers a push pull inverter that I designed too, I want to control the voltage in the buck converter while powering the inverter, the problem I'm facing is that I can control de voltage in the buck converter pretty easy when putting a resistor load, but when I connect the inverter as a load (with a resistor load at the secondary of the inverter's transformer) I can see some high frequency noise at the output of the buck converter and I want to reduced it because I don't want to damage my microcontroller and I'm also getting a bad voltage reading because of this noise, I tried increasing the size of the bulk capacitor of the buck converter and that decreased the amplitude of the noise but made my control system slower, so I think that is not the way to solve the problem. Any ideas?
This is the schematic of my circuit:
Buck converter:
And this is the PCB I designed:
Push Pull Inverter circuit:
Push Pull Inverter PCB
I don't know a lot about PCB design so I probably made a mistake with the design
The Buck converter is control by a PWM of 32 kHz frequency, the push pull inverter is working with 200 kHz of frequency
The noise I'm getting is this:
The frequency of the noise is the double the frequency of the inverter, so I think the problem has to be the inverter
I don't know if this provide some extra information but this is the waveform I get at the secondary of the inverter
The transformer I'm using for the inverter is a toroidal transformer designed for the frequency of the inverter
Please let me know if you need extra information
Thank you for answering :)
In order to reduce deadtime in this design
insert Schottky diode in series gate resistor for fast shutoff and parallel 15 to 45 ohms, try 25 Ohms
--- Updated ---
You can also display Ch1- Ch2 and try to measure DC current in centre tap.
If you are really trying to get the push pull going at 200kHz ( 4.8uS each way + dead time ) - then you will be exciting all the resonances in the unknown transformer.
Without a tightly coupled transformer and VERY short wires to local decoupling - there will be spikes on the Vds of each fet at turn off - that will make it back into the supply bus - in this case the buck converter.
If the Vout of the transformer is at higher voltages - then the capacitance of the windings becomes very important - there will be a main parallel resonance and other resonances ( load dependent ) that will be kicked into action by the fast edges of the driving mosfets - which is why resonant techniques are mainly used to do what you appear to be trying to do.
I will have a more detailed read of the above and see what needs commenting further.
--- Updated ---
The IR2104 cannot give you low enough dead time - per the data sheet:
You need to organise your gate drive such that 200nS dead time ( adjustable ) is obtainable
With just the right amount of dead time you can get a nice resonant transition ( assuming other caveats I posted are followed ) so that when the Vds of the device turning off reaches 2 x Vin the other device is turning on - this leads me to another point -
your turn off gate drive is not aggressive enough - ideally the gate should fall from 10 to zero in 30nS for lossless turn off - here however the slower turn off you have in your ckt at least reduces the Vds overshoot - due to all the wiring inductance !
There is no successful 200kHz operation without the tightest possible layout, i.e wiring L to an absolute minimum - de-coupling as close as possible with quality film and electrolytics ( again with shortest possible leads - ideally all on a multi-layer pcb ) Fet's back to back, etc
p.s. we design power supplies in the 1kW - 4kW bracket that have an operating range of 200kHz - 400kHz
--- Updated ---
Just one further thing - if the capacitance of the output wdg is 120pF say and the inductance of the output winding is say 5.27mH
then the parallel resonance of this combination is . . . . - - - > 200 kHz
if you are unlucky enough to be near this combination - then there will be some high currents flowing in the mosfets, there will also be a sinusoidal output perforce the action of the parallel resonance - the current in the ( nominal )120pF wdg capacitance will be ( @ 565V rms ) 85mA = 48 VA reactive.
p.p.s the freq of the ringing you have observed above, Vds, is a product of the mosfet Cds, and the leakage / wiring inductance of the circuit, as you take away the wiring and leakage inductance ( between LV wdgs - these should be bifilar and intertwined ) then the freq will go up - and the amount of snubbing required to reduce the peaks will reduce - in a very well laid out ckt - no snubbers are required ( we don't need any ).
Good luck.
View attachment 189100In order to reduce deadtime in this design
I'll check if I have Schottky diodes, if not, I'll buy some on Monday. Is a SR100 good enough? Any recommendation? I can easily get SR3100, SR5100 and 1N5819
--- Updated ---
I'm confused, how exactly should the connection be?
Like this?
How many ohms should the series resistor have?
I will have a more detailed read of the above and see what need commenting further.
--- Updated ---
--- Updated ---
Good luck.
Okay, I'm gonna reduce the wires in the transformer, about the driver, I don't know enough driver models, I was thinking in replacing it with a IR2110 or a IR2184 because they can provide a lot more current, but looking at the datasheet the dead time is almost the same, any recommendation?
--- Updated ---
The signal in the center is CH1-CH2
As shown will increase deadtime . WShich is OK . You need to correlate Ciss specs with R*Ciss and gate to drain prop delays to learn this.
The asymmetric delays are already build into your driver but too much for 5 Ohms on this higher RdsOn FET. Rg rises with Rdson which reduces Ciss and Coss due to size.
You may experiment with the R*Ciss delays to get the deadtime reduced. Try change 5 to 25 only , measure before and after delays then compute a correction to speed up the riseing for alling edges to change the deadtime as you like. But parasitics stored energy will respond to a change in switch state. Use A-B or Ch 1-2 as a 3rd channel.
--- Updated ---
How much AC ripple do you have at the centre tap?
Your Caps ought to be within 1 cm of the load.
the dead time for this ckt and 200kHz could well be in the region of 50 - 80nS - looking the the wave-forms given so far,
really this needs a zero dead time drive and the use of Rgate * Ciss to give the turn on dead time, with aggressive pnp assisted turn off to give a very fast turn off.
50~80 ns / 2500 = 2 to 3.2% is your estimate and (350~500 ns)/2500ns = 14~25% was my estimate shown (asymmetric delays). The litz wire delay I estimate as 6~7ns/cm / N strands.
I think the deadtime impedance can be more accurately measured by displaying the centre tap or supply return current at a suitable point and comparing that with Ch1-Ch2 drive voltage, then computing the ratio. This requires a short probe ground loop from star gnd. adding ~ 6.5 ns /cm. delay with ringing.
A 1st order approximation of rise times will be the inductance of primary tap and Rdson of FET.
Tau = L/R @ 63% of step
R= Rdson + wire
Rdson = Vol/Iol
with Tr+ = 35 max and Tr-=25 ns max. on IR2110
2SK3561: RdsOn = 850 mohm max @ 25'C
If Tau were 1us, use RdsOn, L=T/R = 1us / 0.85 = 1.2 uH
Thus reducing the turns will speed up risetimes but increase magnetization current.
When the fet turns off - how long does it take for the Vds to rise to 2x Vin ? - this is all the delay you need for the other fet to turn on, and so on.
" Litz wire delay " is an interesting term, I am familiar with 80% of C for coax, but Litz in a small section would seem to introduce no delay to current rise or fall times - indeed any such " Litz delay " would be swamped by leakage inductance AND Cds and Cwdg - which also set Vds rise times at turn off . . .
All 1st order delays are either Tau=L/R or Tau= R*C
Wire inductance L is reduced by N insulated strands hence I call it Litz wire delay which is lower per unit length, which might be negligible if short from Vcc.
2nd order delays are sqrt {L*C} from driver Coss and interwinding C.
Coax delay line or LC all pass filter is the same delay time for any sqrt{L/C}=Zo
I would imagine leakage inductance for magnetization coupling is at least 10x rated min load impedance.
--- Updated ---
Could you pls give me a diagram? I don't understand how I should to connect the diodes
You schema in #23 shows how to make Turn On delay more than turn off delay where the reference is with respect to Ciss and Rg.
But fundamentally, you need to define all your I/O specs before specific solutions are possible.
Start with a boost inverter with Vdc min:max and Vout min:max and Iout
Are you expecting a sine? If so, you need more than a 2 level switch.
Are you expecting a square wave? then what dI/dt primary and secondary?
I suspect your FET is too high an RdsOn and inductance too undefined for Lp, Lsec and SRF.
I suggest you look at using an 18 mOhm FET rather than 0.8 Ohm one but more important, define your design expectations.
What about the IRFP4668PbF it has RdsOn of 8 mOhm? I would like for the FET to have at least 100V VDS breakdown voltaje
I expect a square wave at the output, I know it doesn't currently look like a square wave but that waveform works for me
until you define all the specs, I cannot advise.
LaTeX Commands Quick-Menu:
