u can use HFSS to do so.it works fine but u know with a finite ground plane your gain would be 3-dB less than what it is supposed to be and the sidelobe levels shoot up.the concept of finite ground plane is when u assign the dimensions of it less than 10*lambda.anything more than that is considered infinite ground plane.
