Githin
Junior Member level 2
- Joined
- Jun 7, 2009
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Clemson, SC, USA
- Activity points
- 1,467
What is the format of the data that I read from the EPROM using a programmer? How do I convert this to assembly language?
As far as I can see, the output from the programmer is Intel Hex format, and has all the fields indicated by the format.
But, I cannot find the same hex codes that I see in the output of the debug -d command of the same BIOS.
Debug -d command dumps the RAM to the screen, so, I can examine the EPROM that is loaded in to the RAM by viewing the hex code. For example, the ascii conversion of this data shows that the code is IBM compatible etc..
What I want to do is to find the assembly instructions by reading the EPROM with the programmer. And, the BIOS was on a Pentium Computer (80586).
