Range of HIGH SPEED clock
tennythomas
Member level 2
What is the range of HIGH SPEED clock?
Thanks in advance.
Depends very much on the field of application. You should try to ask a clear question.
From the net, the high speed clock trace should have specified clearance with other traces while routing. But the frequency of the clock is not given. So i just asked........
If you'll define a "fast clock" net class with specific routing rules also depends on the susceptibility of the other nets to cross talk.
I did it at times for 50 MHz and faster clocks.
