buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 961
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,128
hi
i have some questions about using cadence allegro. and i will have more later.
Q:
- in the Pad Designer (padstack editor), i can sppecify only one diameter for a circle thermal relief for positive planes. But which is that parameter? normally a thermal relief is a pad in a bigger antipad, and there are 2 crossed traces. all of these have dimensions, but which (single) one is what we provide? and what about the other parameters, like the crossed-trace width? where do we specify them?
-how to specify a thermal relief, to get a direct/solid connection to the planes, instead of a real thermal relief? how on positive, and on negative planes?
-in drawing a component footprint. i want to put a pin. i pressed the layout>pins, then i wanted to browse for a padstack, but after pressing the browse button, nothing happens. I can not place any f***** pin for a footprint. what to do?
-i am doing component manual placement. I set the toplayer pads to be red. i switched off all the not important classes/subclasses. but all the component pins look light blue, with very thin 45 degrees red lines. If I move the components, their pins look red. what is it?
Q:
