In case of analog applications , buffer is used as the input stage of the amplifier so that it has infinite i/p impedance and zero o/p impedance and hence gain isnt reduced
For digital appliacations ... which is your case i guess coz u are talking about clock buffer .... we use buffers to drive large capacitive loads to reduce propagaton delay of the digital signal as these buffers are large in size --> have low output resistance .... so delay=0.69*R*C will be small
