Kaze105
Junior Member level 1
Im using codevision to program the ATMEGA16 through a dev board.
Im hoping to connect it to a crystalfontz LCD (link below)
CFA634-TFB-KS, CFA-634 Serial LCD 20x4, RoHS Compliant, White Edge LED Backlight, FSTN
As according to the LCD datasheet, im connecting the port on the LCD called DATA_IN. It is directly connected to the TXD port on the ATMEGA16.
I programmed it to display a simple code (printf("Hello World");
I did set up it up correctly (baud rate, 8 data, no parity, 1 stop). Despite checking it again and again, I cannot get it to display anything so I wanted to confirm that what im doing is correct with the ATMEGA16.
In order to get TXD port to output to the LCD, I just need PORTD set up as an ouput, is that correct? Do I need any other setting to specifically set it as a TXD port?
