Question on BiCMOS Inverter
mujju433
Full Member level 3
Hi Everyone,
Please find the attached document for the BiCMOS Inverter and clear my doubts. I have posted the entire explaination of the same and at the end there are 2 questions.
Regards
Mujju433
  • New Microsoft Office Word Document (3).doc
Condition I:
@ Vin= LOW, when Vdd-Vc(out)High<Vbe2(cutin) - Q2 is OFF
Condition II
@ Vin= HIGH. When Vc(out)LOW<Vbe1(cutin)- Q1 is OFF
with an assumption that the Vds(sat) of Mp and MN are negligible
Dear CM Krishna,
In the text it says that in condition 1 , Capacitor charges to Vdd-Vbe , i.e assume 5-0.7 =4.3 and then it fully charges when Q2 cuts off, As per your reply , Vdd-Vc<Vbe2 and Q2 is off , How?, What is the value of Vc here?
Initially Q2 is ON, What makes it off?
Hi mujju
Please find enclosed here with the simulation waveform of the circuit:
The enclosed waveforms starting from bottom indicate 1) MoS Inverter output 2)The current waveform thru Resistor(5K used) placed across top BJT Emitter base (This shape also indicates the Emitter base Voltage wave shape).3)Base current of top BJT 4) Current thru the Load capacitor.
From the waveforms we observe that the PMOS Drain drives current thru { Resistor(5K used) and top BJT Emitter base combination } into the load capacitor.The BJT will conducts when its Vbe is greater than cutin voltage and charges capacitor thru collector emitter within a short period.
once the capacitor is fully charged, as there is no more charging current thru resistor, there by no Vbe(cutin) potential and hence BJT will be in cut off for rest of the cycle period.
