question on Allpass filter
gadagkar.rohit
Junior Member level 2
San Jose
Hello,
I am designing an all pass filter which is a part of a reverberation generator for audio inputs. I am implementing it in verilog.
The difference equation that i am using is
y(n) = x(n-N) - g*x(n) + g*y(n-N);
g - gain, N - filter order
the transfer function is H(z) = [-g + Z^(-N)]/[1 - g*Z^(-N)]
With g = 0.2, when I give a sine input at 5 KHz at -40db, the output is +5db. so the gain is 45db.
I am really confused with the overall result. how exactly is the value of g affecting the gain.
Please let me know if I ve gone wrong at any step or my understanding. Please help me with this.
when i plot the frequency response using matlab with filter coefficients b = [-0.2 0 0 0 1] and a= [1 0 0 0 -0.2] i got a flat spectrum (here N = 3, g = 0.2). or for that matter with any value of N, i got a flat spectrum.
i used freqz(b,a).
---------- Post added at 09:47 ---------- Previous post was at 09:41 ----------
initially i was given this equation to use,
y(n) = g*y(n-N) - x(n) + (1+g)*x(n-N);
but that equation didnt give a flat spectrum. does this look like one?
For different frequencies, you get different gains and different phases (lags). g is a filter parameter, which is not directly related to the filter overall gain on a given frequency. U can plot |H(jw,g)| for the fixed frequency of 5kHz to see how g affects the filter gain at that frequency...
Hello RaulPinheiro,
Thanks for the reply.
Am I doing anything wrong here - b = [-0.2 0 0 0 1] and a= [1 0 0 0 -0.2]. or is my difference equation correct?
Thanks for you help
y(n)- g*y(n-N) = - x(n) + (1+g)*x(n-N);
(1-z^-N)Y=(-1+(1+g)z^-N)X
H=Y/X=(-1+(1+g)z^-N) / (1-z^-N)
for N=5
b=[-1 0 0 0 0 (1+g)] (numerator)
a=[1 0 0 0 0 -1] (denominator)
note that for N=5, a and b are length 6
You must study some dsp in order to implement a filter.
Otherwise, u wont have a clue on what u're doing...
Raul
Hello RaulPinheiro,
Thanks for you help
---------- Post added at 12:46 ---------- Previous post was at 12:44 ----------
CORRECTION
(1-gz^-N)Y=(-1+(1+g)z^-N)X
H=Y/X=(-1+(1+g)z^-N) / (1-gz^-N)
for N=5
a=[1 0 0 0 0 -g] (denominator)
Raul
Hi Raul,
Thanks for the reply. when i plotted the response of the filter that you gave. It looks like a multinotch filter.
I ve attached it. Please have a look.
Hi Raul,
jdghjdjdjjtdujtuteutedyu
