question about pid control
mana111
Member level 1
Member level 1
Hi
I'm developing a thermistor pic16f876 based temperature controller and it worked successfully and now i want to make it work with PID, And i learned that the P,I,D constant are gained expermently So i have question here
many companies provide PID temperature controller wothout adapting it on the clients systems so how can they make it?
another one
which is better fuzzy or the PID control??
Thanks In Advance
I suspect that they set the values based on the worst case load thermal mass.
The PID method was invented for foolproof experimental optimization of the system. It is not as good as the Nyquist method or the optimal control method but requires less system information to adjust.
It is better than the on-off limit method though. Many heating systems like room temperature control work well with the on-off method because the temperature variation is not noticed much by people. In chemical reaction situations, like colour photography processing, the temperature has to be held within 1 C or less variation.
hi m also working on the same project i have designed the p and i part. but notgeting wht to do with d ,how to make it control?
can u please help flatulent
The general adjustment procedure is to set I and D to zero effect and increase P until the transient response starts to ring. Then increase D to bring the ringing down and this allows you to increase P again. (Remember that higher gain {P} in a control system reduces the error of output verses what you wanted.)
Once these two are adjusted to your liking, I is adjusted to reduce steady state error.
hi
thanx all
i heard about what called self tuning
could this be a routine in the software which adapt the controller by it self?
It is possible that the tuning procedure I described could be done by the software.
    mana111
#include <string.h>
#include <stdio.h>
PID Function
The PID function is used in mainly
control applications. PIDCalc performs one iteration of the PID
algorithm.
While the PID function works, main is just a dummy program showing
a typical usage.
typedef struct PID {
double SetPoint; // Desired Value
double Proportion; // Proportional Const
double Integral; // Integral Const
double Derivative; // Derivative Const
double LastError; // Error[-1]
double PrevError; // Error[-2]
double SumError; // Sums of Errors
} PID;
PID
double PIDCalc( PID *pp, double NextPoint )
double dError,
Error;
Error = pp->SetPoint - NextPoint;
pp->SumError += Error;
dError = pp->LastError - pp->PrevError;
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error
+ pp->Integral * pp->SumError
+ pp->Derivative * dError
Initialize PID Structure
void PIDInit (PID *pp)
memset ( pp,0,sizeof(PID));
Main Program
double sensor (void) // Dummy Sensor Function
return 100.0;
void actuator(double rDelta) // Dummy Actuator Function
void main(void)
PID sPID; // PID Control Structure
double rOut; // PID Response (Output)
double rIn; // PID Feedback (Input)
PIDInit ( &sPID ); // Initialize Structure
sPID.Proportion = 0.5; // Set PID Coefficients
sPID.Integral = 0.5;
sPID.Derivative = 0.0;
sPID.SetPoint = 100.0; // Set PID Setpoint
for (;;) { // Mock Up of PID Processing
rIn = sensor (); // Read Input
rOut = PIDCalc ( &sPID,rIn ); // Perform PID Interation
actuator ( rOut ); // Effect Needed Changes
    mana111
flatulent ,Do you have any examples?
xiaoqun, Thanx but soory i don't use C . Is this a normal PID or auto tuning ?
As you see ,these are initialization code.So this is not a auto tuning PID.
Which language do you use? In assembly,it's very hard to deal with 16 bit and floating point arithmetic.
No, I'm using basic
and i have a code for pid but the my problem is in the constants
