AkisTzortzis
Newbie level 3
Hello
I would like to make a transformer with a primary winding of 5 Volts RMS and current of 40 Ampere RMS. Its secondary winding ought to be 35 Volts RMS and 4.5 Amps RMS.
I presume that means the turns ratio should be 1:7 (from 5 Volts to 35 Volts) ?
I am not sure how to select the core , would a toroidal be best? And how about the wire? How thick a wire I need to handle 40 Amps on the primary? And how many turns do I need? For example what is the difference between having 10 primary turns and 70 secondary, or 100 primary turns and 700 secondary?
As I need to have 40 Amps flowing through the primary, at 5 Volts RMS, do I take it that the primary winding would need to have a resistance of 0.125 Ohm? How do I go about choosing the right wire and right number of turns to achieve 0.125 Ohm? And how on earth do I measure such a small resistance?
Any help appreciated.
