How changing the driver cell can help fix the setup?
Also, why should we change the driver strength of the cells which has cross talk effects to fix setup?
the cell with a higher strength propagates the signal faster, cos of bigger size ( correct me if i am wrong)
so since in the setup chk, u always chk for the data to arrvive well b4 clk ... replacing the cell with a higher drive strength actually propagates the signal faster .... hence u can meet the setup time !!!
