soumyabumba
Junior Member level 1
I am planning for a PLL with mixer in feedback path for down converting to lower the N-value. Please discuss some doubts that i am having.
1. If the PLL output noise calculated from 20log(N) is for example 120dBc/Hz@10kHz offset and the LO used to down convert it has 90dBc@10kHz offset what will be the overall phase noise and how to calculate it?
2. If the LO signal is generated from an up conversion of another PLL and a DDS, is it necessary to use SSB mixer there?
