Proteus simulation working but lots of simulation messages
lloydi12345
Member level 4
Hi, I'm using C18 and everything works fine. Compilation succeeded. But the problem is I'm encountering thousands of warning messages on Proteus. Here's the same warning message:
PIC18 EXEC) PC=0x0032. Attempt to execute illegal opcode (loaded from PC=0030). Instruction executes as a NOP.
Here's my code:
#include <p18f4620.h>
#include <delays.h>
#pragma config OSC = XT
#pragma config LVP = OFF
#pragma config WDT = OFF
int counter = 0;
int enabler = 1;
int enabling = 1;
int timing = 0;
#pragma interrupt maketime
void maketime(void)
	PIR1bits.TMR1IF = 0;
	timing++;
	if (timing == 5){
		PORTEbits.RE0 = ~PORTEbits.RE0;
		timing = 0;
	if (counter > 9){
		counter = 0;
void numberselector(unsigned int SevenSegInput)
	switch(SevenSegInput){
	case 1: LATC = 0xF9; break;
	case 2: LATC = 0xA4; break;
	case 3: LATC = 0xB0; break;
	case 4: LATC = 0x99; break;
	case 5: LATC = 0x92; break;
	case 6: LATC = 0x82; break;
	case 7: LATC = 0xF8; break;
	case 8: LATC = 0x80; break;
	case 9: LATC = 0x98; break;
	case 0: LATC = 0xC0; break;
void main()
	PORTA = 0x00;
	PORTB = 0x00;
	PORTC = 0x00;
	PORTD = 0x00;
	PORTE = 0x00;
	LATA = 0x00;
	LATB = 0x00;
	LATC = 0x00;
	LATD = 0x00;
	LATE = 0x00;
	TRISA = 0xFF;
	TRISB = 0x00;
	TRISC = 0x00;
	TRISD = 0x00;
	TRISE = 0x00;
	ADCON1 = 0x0F; //all I/O are digital
	T1CONbits.RD16 = 1;
	T1CONbits.T1RUN = 0;
	T1CONbits.T1CKPS1 = 0;
	T1CONbits.T1CKPS0 = 0;
	T1CONbits.T1OSCEN = 0;
	T1CONbits.TMR1CS = 0;
	T1CONbits.TMR1ON = 1;
	PIE1bits.TMR1IE = 1;
	IPR1bits.TMR1IP = 1;
	INTCONbits.GIE = 1;
	INTCONbits.PEIE = 1;
	TMR1H = 0x00;
	TMR1L = 0x00;
	LATC = 0xC0;
	while(1)
		numberselector(counter);
Hoping for usual quick replies. Thanks :)
are you sure you are simulating the same pic in proteus????
any way it seems an clasical "invalid extended instruction set" maybe in C18 or in proteus it has the Extended instruction set mis-enabled i suggest to disable in code, in options and in proteus...
