Proteus 8 Problem/Bug
why can't I run the circuit that I attached, while my lecturer can run it, I put the hex file correctly at 2732, why it still doesn't work, I checked again the version of proteus.co.uk which can run (marked with a component with the display < TEXT>), while the proteus.com version cannot run.
Help me, I've downloaded 15 versions and still can't get it
"I can´t run ..." is no error descripton.
We don´t know what´s happening. (unless you tell) Is there an error? What do you expect ... that does not happen.
I can see the messages are marked with a yellow caution sign. Not Red cross. So, there are no errors here. Only warnings. If you are not getting expected result, please check the code that you are trying to upload. Click on the warnings and see what they say. In case you are facing problem with any library installation, this is how you can do it. https://www.theengineeringprojects.com/2018/04/how-to-add-new-library-in-proteus-8.html
LaTeX Commands Quick-Menu:
