Problem with Triac after some time working it burned.
xxtigerxx
Advanced Member level 1
Greece
I design a board with 3 triac output.
The power supply is 220VAC and i want to give 150VAC to a load.
The load i a switching AC/DC load with power max cons. 40VA.
I detect zero cross and i trigger the MOC for 1ms only.
The problem is that after some times a triac is "burned".
I am using the below curcuit.
Can you help me?
Add a resistor ~10K between 'G' and 'T1' otherwise the gate is left floating when the MOC3023 is turned off. Also ensure you are getting enough gate current through the 1K8 resistor, it would be worthwhile following the data sheet of the MOC3023 which shows a recommended schematic.
Brian.
Reactions: alexxx
    alexxx
Hi Brian, thanks for the response.
The mains input is on T2 and the load output is on T1. Is this you had in mind about the 10K resistor? Add it between gate and load output? By the way, does the order of T1 and T2 makes any difference? It should the same, isn’t it?
I read the MC3023 datasheet and it has the below circuit
Reactions: alexxx
    alexxx
You should not cross T1 and T2, they are different inside the triac, they have a PNPN construction with the gate one junction from the end, not in the middle.
Yes, adding the resistor between T1 and G according to your original schematic is what I meant and yes, I suggest you use the schematic you show from the data sheet for best reliability.
Brian.
Hi brain,
Can you help me choose the right triac? it must be 4Q or 3Q? Igt less than 10mA? Voltage 600 are ok?
What is your load?
You said you were using three triacs to drop 220V to 150V with a 40VA load, that is only about 0.2A but the sine wave will be seriously distorted so an inductive load may try to draw considerably more.
Brian.
Brian the load is a AC/DC offline swither 40VA / 30W.
So what do you think must be the characteristics of the triac?
Hi Brian.
I came up to 800V/4A triac. 4Q, non sensitive gate. Is this well suited for this load?
What should be the wattage of this resistor between G-T1
Thanks.
That should be fine.
Use 0.5W resistors, when the MOC is turned off the current is very small so almost no power is dissipated in the resistors, when it is turned on, the voltage across the triac is only a few volts so again the current is quite small.
Brian.
hi betwitx i tried the reistor but still the triac failed(burned).
Maybe the problem is with the load. the load is a offline switcher max 40W.
Do you think that a choke or a common choke would help?
