problem with timer for create the delay
raja.afiq
Newbie level 3
Newbie level 3
i using pic18f4550. i made a coding as salve to run a servo motor. i try to make a delay using TMR0.
this is one of my code for delay
i define freq as 20Mhz
 void delay_tanda1 (void){
 w=1850;   //i using this because w will be variable that come from master
 T0CON=0b01001000;   // 8bit timer, prescaler 1:64
 TMR0H = 256-((w*freq)/(256))
 TMR0ON = 1;        // Turn On Timer0
 while (TMR0IF==0);  // wait until overflow
 TMR0ON = 0;         // Turn off timer 0
 TMR0IF = 0;         // Reset timer0 flaq
the problem is why the TMR0ON=1; in the coding have error: expression syntax. because i use the same coding for other program and it work. TMR0H in that program i use actual value in hexa.
thank.. it just because i left the ";" at the end of it. i did not notice that.
