zainul
Newbie level 5
I simulated S-Parameter of many patch arrays using momentum than had a problem with time processing and memory. The process stopped because it was not enough memory (the memory is 1.5 G), If I reduced the mesh number, there was a warning which said my simulation would not be accurate.
Is there any solutions instead of reducing mesh?
Thanks for advance
Thanks for advance
