Willykilly
Junior Member level 1
second order lpf
I designed a low pass filter as per the circuit given in
https://www.sensorsmag.com/da-contr...rder-anti-aliasing-filter-a-sensor-signa-5861
but the signal output is not coming correctly. For a sine wave input it gives out 3/4 of positive half correctly but the negative half of the sine wave is distorted and I do not know what shape is that. What could be the problem. I am using exact vales of components and I asked my friend to verify the connections after verifying the connections myself.
Thanks in advance.
Thanks in advance.
