agnostos
read from gsm modem
hello i have a problem with avr and gsm modem.
i can send AT commands to gsm modem but i can't get the returns. how can i read the return value of AT command???
i have the avr stk500 and i send the at command with printf("AT");
i try to read with this way
char myData[50];
scanf("%s",myData);
but nothing happened why???
my code is
char myData[50];
scanf("%s",myData);
my code is
This program was produced by the
CodeWizardAVR V1.25.9 Professional
Automatic Program Generator
© Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
[url]http://www.hpinfotech.com[/url]
Project :
Version :
Date : 16/5/2008
Author : ditoskas
Company : ditoskas
Comments:
Chip type : ATmega8515L
Program type : Application
Clock frequency : 4,000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 128
#include <mega8515.h>
//TA CR KAI LF XRISIMOPOIOUNTAI GIA TIN APOSTOLI TOY ENTER.
#define CR 0x0D
#define LF 0x0A
//DEKAEKSADIKI TIMI TOY CTRL-Z EINAI I 0x1A.
#define CTRLZ 0x1A
#include <delay.h>
// Standard Input/Output functions
#include <stdio.h>
// Declare your global variables here
//char msg[127];
char myData[127];
void SendSms(void)
printf("at+cmgs=6938699188");
putchar( CR ); //CR
putchar( LF ); //LF
delay_ms(100);
printf("%s",myData);
putchar(CTRLZ);
// putchar( LF ); //LF
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=Out Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=1 State0=T
PORTC=0x02;
DDRC=0x02;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
// Func2=In Func1=In Func0=In
// State2=T State1=T State0=T
PORTE=0x00;
DDRE=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
EMCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 115200
UCSRA=0x00;
UCSRB=0x18;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=4000000/16/115200-1;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
PORTB.0 = 0;
PORTB.1 = 0;
while (1)
printf("%s","AT+CMGR=1");
putchar( CR ); //CR
putchar( LF ); //LF
PORTB.0 = 1;
delay_ms(100);
PORTB.0 = 0;
scanf("%s",myData);
// Place your code here
delay_ms(1000);
PORTB.0 = 1;
SendSms();
delay_ms(2000);
PORTB.0 = 0;
break;
