[SOLVED] Problem with LM35 negative temperature reading
Praveen Kumar P S
Member level 4
India
Hello friends...
This program is for reading the Temperature and display it on a lcd display at the same time the pic serially transmit the temperature.....My program works.....:roll::roll:..But it is not displaying any negative temperature....:bang::bang::bang:
plzz help guys...............
Here is my code:::
#include <18f4550.h>
#device ADC=10
#fuses HS,NOWDT,NOPUT,NOPROTECT,NODEBUG,BROWNOUT,NOLVP,NOCPD,NOWRT
#use delay(crystal=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include<flex_lcd416.c>
void main()
unsigned int8 t;
lcd_init();
lcd_gotoxy(4,1);
lcd_putc("Temperature\n");
setup_port_a(ALL_ANALOG);
setup_adc( ADC_CLOCK_INTERNAL);
setup_adc_ports(AN0);
for(;;)
set_adc_channel(0);
delay_ms(10);
t = read_adc()/2;
lcd_gotoxy(6,3);
printf("Temp::\t%3.0u \xDFC\n\r",(unsigned int8)t);
printf(lcd_putc,"%3.0u \xDFC ",(unsigned int8)t);
delay_ms(10);
Is your adc able to decode negative voltage?
If yes, did you negative bias with resistor your lm35 output?
your variables are unsigned, e.g.
unsigned int8 t;
and the printf() conversion specifications etc are for unsigned types
if you expect negative values should you be using signed types?
I connect output of lm35 directly to AN0 pin of the pic.....i didnt have a -ve bias with resistor.....
why is the resistor for.....??
thank you....
plzz help
i changed my program but still no effect...........
here is my new code..
#device ADC=10
void main()
signed int8 t;
lcd_init();
lcd_gotoxy(4,1);
for(;;)
set_adc_channel(0);
delay_ms(10);
t = read_adc()/2;
lcd_gotoxy(7,3);
printf("Temp::\t%3.0d \xDFC\n\r",(signed int8)t);
printf(lcd_putc,"%3.0d \xDFC ",(signed int8)t);
delay_ms(10);
guys...any hing wrong with my code...plz help
thank u....
hello,
What is the specsheet of your LM35
is it a LM35DZ or a LM335
LM335 can measure negative temperature, LM35DZ can NOT ...
if you can use 4.096V as +VREF and use -VREF with a resistor divider by 2 sor -VREF=2,048V
you can have a scale of 2048mV for 1024 points
and measure from -68.2°C up to 136.6°C with a resolution of 0.2°C
see table..
problem:
signed int8 ?
an int is 16 bits..
why not simply use
int t;    // must be an int signed
because read_adc must be an integer ( with only 10 bits used inside the result)
%3.0 decimal, is reserved for floating point
you must write %3d
printf("Temp::\t%3d \xDFC\n\r",t);
why divide Adc result by 2 ?
you measure is a raw measure in points, you need to convert it in °C or °F
see correspondance table for a LM335 ..
Positive is upper 2730mV = 0°Kelvin
[Merged]CanT read data from sensors....!!!
Hello guys....
i dont why my program is not working.....It read values from the sensors...but not showing any correct temperature and my humidity sensor output always zero.....
here is my code....:::
#device ADC=10
#fuses HS,NOWDT,NOPUT,NOPROTECT,NODEBUG,NOLVP,NOCPD,NOWRT,NOMCLR,INTRC_IO,NOPBADEN,BROWNOUT,PUT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
void main()
unsigned int8 t0,t1,T;
unsigned int8 h;
lcd_init();
setup_adc(ADC_CLOCK_INTERNAL);
setup_adc_ports(ALL_ANALOG);
set_adc_channel(0);
delay_ms(10);
t0=read_adc()/2;
delay_ms(10);
set_adc_channel(1);
delay_ms(10);
t1 = read_adc()/2;
delay_ms(10);
T=t0-t1;
lcd_gotoxy(1,2);
printf(lcd_putc,"Temp::\t%3.0d \xDFC ",(signed int8)T);
printf("Temp::\t%3.0d \xDFC\r",(signed int8)T);
set_adc_channel(2);
delay_ms(10);
h=read_adc()/2;
delay_ms(10);
lcd_gotoxy(1,1);
printf(lcd_putc,"Humidity::%3.0u",(unsigned int8)h);
output_high(PIN_B3);
plzz help me........:bang::bang::bang::bang::bang::bang:
Re: [Merged]CanT read data from sensors....!!!
Here I am attaching LM35 firmware and Proteus simulation. If you need more precise measurement then I will use Vref+ and make it. :thumbsup:
  • LM35 Negative Temperature Measurement.rar
  • LM35 Negative Temperature Measurement rev1.rar
