Problem with LM35 code as the LED is blinking
delifadzli
Member level 2
malaysia
#include <16F877A.H>
#device ADC=10
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 20000000)
#include "E:\note ngaji\FYP\stuff last sem\code\led experiment\brum\Flexlcd2.c"
void main(void)
int16 temp_adc;
int temp;
setup_adc(ADC_CLOCK_DIV_8);
setup_adc_ports(PIN_A1);
set_adc_channel(1); //read analog input from channel 1
lcd_init();
lcd_putc("\fTemperature:\n");
while(1)
temp_adc = read_adc();
temp = 5.00*temp_adc*100.00/1023.00;
lcd_gotoxy(1,2);
printf(lcd_putc,"%d",temp);
delay_ms(3000);
if ((temp<20) && (input(PIN_B7)==1))
output_high(PIN_D7);
delay_ms(100);
else if ( (temp>= 20) && (temp_adc <30) && (input(PIN_B7)==1))
output_high(PIN_D6);
delay_ms(100);
else if ((temp_adc >= 30) && (input(PIN_B7)==1))
output_high(PIN_D5);
delay_ms(100);
else
output_high(PIN_D4);
delay_ms(100);
here is the source code that using LM35 as a sensor...
here i like to experiment with the temperature produce by LM35 to produce LED output.. For example, if the temperature >>30 deg--- the LED at Pin D5 should be on...am i right...the problem....the led doesn't on...easy compulsory to connect the LED with resistor??...urgent...even if u see it might be too simple for ur guys...
Added after 1 minutes:
#device ADC=10
void main(void)
       int16 temp_adc;
       int temp;
        lcd_init();
          while(1)
         lcd_gotoxy(1,2);
            delay_ms(3000);
         delay_ms(100);
         delay_ms(100);
         delay_ms(100);
       else
      delay_ms(100);
correction
isn't compulsory to connect the LED with resistor....sorry for my english
want to ask....
what is the problem?
please be clear
Re: want to ask....
the LED just blinking . For example if temperature - more than 30 degree... the LED at pin D5 just blink...not totally on....isn't the code wrong?
Added after 27 minutes:
#device ADC=10
#define      LED1     PIN_D7
#define      LED2     PIN_D6
#define      LED3     PIN_D5
#define      LED4     PIN_D4
void main(void)
       int16 temp_adc;
       int temp;
        lcd_init();
          while(1)
         lcd_gotoxy(1,2);
            if(input(PIN_B7)==1)
    if((temp<20))
       //delay_ms (500);
      output_high(LED1);
   }    else
      output_low(LED1);
    if ((temp>= 20) && (temp_adc <30))
      output_high(LED2);
      else
     output_low(LED2);
     if ((temp_adc >= 30))
       output_high(LED3);
     else
     output_low(LED3);
else
ok...i managed to find the problem...mistype the delay value...done...thanks for ask....
want to ask....
you definitely can benefit a class or two on structured programming.
