dsanthosh67
Member level 4
I have a wifi module which is operated at 2.8VDC, Operation wise its works fine but am facing a problem while using different power. I have a regulator MCP1826 which is used to convert 2.8VDC from 4V when battery voltage is at fully charged condition. For power supply when i connected 5V adaptor through MCP1826 regulator wifi gets Turn On normally, but when i connect battery wifi not able to Turn On.Kindly give some suggestion to solve the issue.
5V adaptor have 1000mA rating, 3.7V battery have 1200mA.
